AVS › AVS Forum › Audio › DIY Speakers and Subs › Need someone to perfom WinISD Voodoo Please XD
post #1 of 8
Hi, I would really appreciate if someone could model 2 of these 15 inch drivers for me in a 4.2 cubic foot box tuned to 23 Hertz. I really appreciate it!
Re : 3.8 ohms
Fms : 21.0 Hz
Res : 49.6 ohms
Qms : 4.57
Qes : 0.63
Qts : 0.56
Rms : 6.9 kg/s
Cms : 0.24 mm/N
Mms : 238.0 gr
Nref : .33%
Bl : 13.7 n/a
SPL : 87.2 dB
Vas : 231.8 L
Rp : 27.8 ohms
Lp : 50.8 mH
Cp : 1503.4 uF
Le : 2.82 mH
Rms : 600 Watts
2.5" Voice Coil
post #2 of 8
Xmax is 22mm and going to be on 1200 Watts RMS
post #3 of 8
one driver in that enclosure.
374
two drivers.
394
you're welcome. :-)
post #4 of 8
Thanks! Why does it look so horrrribblee frown.gif Already bought the drivers lol
post #5 of 8
i'm sorry that you are a little disappointed there. the drivers just have really weak motors and can't push against the air pressure of a small sub.
post #6 of 8
if they are going in a car, it might be ok because of the huge cabin gain that you will get.
post #7 of 8
So it would improve if I increased box size? (its going in home)
post #8 of 8
it would.
also going to a sealed design would help even more.
if you go with 6 cubic feet for each cab and run a total of 1200 watts, you will be shooting just over xmax by a few mm, which is ok.
they will not have that big hump and should get you over full reference spl in room. room gain starts kicking in for a medium room around 25-30hz, so the real response will be much flatter than the model. ignore everything over 80hz.
440
Edited by LTD02 - 6/30/12 at 10:44pm
