Certainly the debate of Plasma vs. LCD/has been discussed and will continue to be discussed. That said, in most real world, everyday viewing environments, plasma panels are irksome and really a compromise. A TV should be able to display a bright image during daytime viewing with higher ambient light levels. What some consider as "overly bright" is an excuse for "not bright enough" and overly glossy glass screens of most plasma TVs. Color accuracy and black levels are where a plasma excels to be sure, but only if you are willing to allow for the very real image retention, screen burn issues, running "slides" for a break in period and other finicky issues.
All one needs to do is go to a number of outlets selling both plasma and LCD/LED and see that, over all, plasma displays are inexpensive, but can't seem to quite compete with LCD/LED panels costing only a bit more these days. And some brands still seem to have complaints of "floating" or rising black level after hours of operation. Plasma TVs seem to require a bit more routine maintenance to continue the better perceived level of picture quality. Lastly, it is plain to see that TV makers are spending most of their research and development in other flat panel improvements including LED/LCD.
I never stated break in had anything to do with screen burn. It was merely the second point in one sentence dealing with several issues that plasma panels exhibit. An assumption on your part.
Still, it does bring up another "fussy" thing about plasma panels.
Edited by Phase700B - 7/5/12 at 6:53pm
Originally Posted by Guibs
This is NOT the reason people "break in" their TV. It has NOTHING to do with IR. Plasma color and brightness tend to shift withing the first 100 or so hours. After that it settles to what should be their final level. most people break in their TV because they want to accelerate that period so that they can get their TV calibrated without fear that their actual colors and brightness will continue to fluctuate.
It's pure myth that this "help" regarding burn-in.
Still, it does bring up another "fussy" thing about plasma panels.Edited by Phase700B - 7/5/12 at 6:53pm
