"lol, its more like I have X engine what car should I put it in."
nope, crazy ivan is correct.
it is more like how big is your room, how loud do you want, how low do you want, and what drivers/enclosures do you plan to use.
answering that might make a 100x or more difference in what kind of amp that you need.
for example if you have a lot of space and don't need much below 20hz, a tht or f20 might work. neither require much power. 100 watts might be fine.
if you want to do small sealed cabs with a bunch of subs and need enormous output at 10hz in a large room. 10,000 watts might not be enough.
edit: this new site is very difficult to work. all the adds are slowing me down like nothing before. just a heads up avs.
