AVS › AVS Forum › Audio › Receivers, Amps, and Processors › How to bridge power amp Carver av-806x?
post #1 of 7
From the picture, how to bridge power amp Carver av-806x?
post #2 of 7
Some amplifiers have circuitry that allows them to be bridged, and some can be damaged if you bridge them. When in doubt, DON'T.
I suggest that you NOT try to bridge it unless the factory manual has specific instructions on how to do it properly.
post #3 of 7
http://www.audioreview.com/cat/amplification/amplifiers/carver-audio/av-806x/prd_115666_1583crx.aspx
I read from the links some one said that ,
6 channels @ 135 watts each into 8 ohms
Uses "power steering" technology
2 channels are bridged creates 365 watts per channel into 8 ohms
can be used as a 3,4,5 or 6 channel amp.
post #4 of 7
Treisara, how would you like to bridge it?
If you want three pairs then #3inv o/p to #6 i/p, #2inv o/p to #5 i/p & #1inv o/p to #4 i/p. Pre-amp outputs go to #1 i/p, #2 i/p & #3 i/p.
Speakers are connected to RED terminals ONLY, 6 -ve 3 +ve, 5 -ve 2 +ve, 4 -ve 1 +ve.
Any questions feel free to email me at gregmay@netzero.net, if you want a pdf of the manual send me your email and when I get back to work next week I will scan it and email the scan to you. Hope that helps.
Greg.
post #5 of 7
Greg.
Blue hilight, is it connecting by jumpers?
post #6 of 7
Yes, short coaxial audio cable, inverting output of one channel to the input of the adjacent channel. Don't forget to only use red speaker terminals. I use this configuration to drive my front L/C/R speakers, then I use the 5 amplifier channels of my Harman Kardon to drive my sideL/sideR/rearL/rearR/rearC after I have processed the HK rear L/R channels with a Lexicon CP-1. If you want a copy of the manual I can scan it to a PDF and email it, just send me your email or PM me if you want a copy.
post #7 of 7
Grag, thank you for your advice .
