AVS › AVS Forum › 3D Central › 3D Source Components › Edius 6.5 available!
Edius 6.5 available! - Page 6
post #151 of 156
Thậm chí nếu bạn tìm thấy một liên kết tải về, bạn sẽ cần một chìa khóa để mở khóa nó.
post #152 of 156
post #153 of 156
It's Vietnamese and I think he was asking for a link to download Edius for free. If there is a free download link, Wolfgang, maybe you could just post it but I told him he may need a key that cost money to use it. He said he has spent over a month trying to find it. Maybe the website is blocked in Vietnam.
post #154 of 156
Don Landis and Wolfgang S.
Thank you for your guidance throughout the year and wish you a happy holiday season
cordially
Jacques
amateur 3D
I Escusez Google translation
post #155 of 156
For free is the trial only - that can be downloaded after registration here:
http://www.grassvalley.com/products/editors
But there is no hack or crack available as far as I know, the system seems to be quite secure.
post #156 of 156
Hi,
i come from Vegas and now try Edius 6.5 trial.
Although i found some cool things (see below), i also have some question:
- is it possible to set the preview monitor to side by side full, like in vegas?
i have a little color mismatch between left/right, and it's easier to adjust in full,
than in half sidebyside mode
-where is a simple levels adjust filter? you know input start, input end, gamma, etc.
i only see yuv and color wheel filters
- can i set edius to show the effect parameters window immediately as i drop it
to a clip? now i have to double click on the name in the information window.
- is there any benefit to set the project to 10bit instead of 8 if i only work with
TD10 and gopro files?
- is there any timeline frame server plugin? (like debugmode)
And now the good things:
- far better preview performance than vegas
- stereoscopic adjust auto correct function works in 0 second while vegas
- rendering the same clip with little CC, stereo adjust and sharpen to HQX avi
from Vegas is 25 sec, from Edius is unbelievable 4 sec!
regards!
  Back to Forum: 3D Source Components
