AVS › AVS Forum › Audio › Speakers › Thoughts on if this Atlantic Tech trio could work up front: 3200 center + 8200 L & R
post #1 of 5
So i was looking at center channels that would fit nicely below my wall mounted TV on the mantle and I came across the Atlantic Tech FS-3200. It will fit just fine. The next question is what to pair it with? I have quite a bit more room to the left and right. There are two sets of built in shelves that could easily handle a larger pair of speakers, especially if I turn them horizontally. I was thinking I could step up on the left and right channels to the 8200 or 6200 series. Anyone have a setup like this? Thoughts on how these would match? Alternatively I can go with the 3200 as well on the right or left, or try to make one of the larger centers work (likely would have to be positioned on the floor right in front of a marble fireplace.
I'd appreciate any thoughts, comments, alternative suggestions?
post #2 of 5
Why not just use the "matching" LR's?
190
Craig
post #3 of 5
I agree with Craig John, match all three across the front. If you have any questions, let us know.
post #4 of 5
Same vote here - match the FS-3200, Atlantic is good
post #5 of 5
I was wondering if that would be the consensus view. I just figured the higher end L & R's might outweigh not matching the 3 speakers. Sounds like the matching is getting more votes. Thanks.
  Back to Forum: Speakers
