AVS › AVS Forum › Audio › Speakers › Onkyo 616 / Denon 2113 with Dali Zensors?
post #1 of 4
Hi all,
I've been looking at getting an AV Receiver now for quite a while, and to be honest I am still deliberating on which one to get! However, I have recently been offered a deal on the Onkyo 616 or the Denon 2113 ( I get to choose ) with the Dali Zensor 5 Speaker Set. The offer for this was for £1300 - now that's a great deal for me!!
However, I'm wondering if the Dali's are as well respected as the reviews say? I don't have a huge room for this, it's just a normal size livingroom - will the Dali's be overkill? What does everyone think about KEFs? They seem very nice too smile.gif
Probably a naive question, but does it really matter which speaker set to hook up to different model receivers? The thing I liked about the Dali 5's was the 2 front floor standers, and the rear 'satellites'.
To be honest I'm a little clueless when it comes to speakers, so would appreciate any advice!
Thanks in advance!
post #2 of 4
It is an excellent set of speakers, especially for that price! KEF speakers would also be nice, but I doubt if the KEF speakers of equal quality would be available for the same price.
I would recommend the Denon receiver, because Onkyo reliability has been rather poor. The Denon has pretty good sound quality and power for its price.
I would recommend that you jump on that setup while that price is available; you can't go wrong!
Originally Posted by brw2012 View Post
Hi all,
Thanks in advance!
post #3 of 4
Thanks for the reply there!
That's what I was thinking - very good price for the setup....Do different Amps sounds better through different speakers, i.e. do they couple better with certain brands?
The KEFs I had in mind were the 3005SE-W's - thoughts?
post #4 of 4
I am not familiar with those; I had some KEF iQ9 speakers which were excellent, and the Q900 are also excellent.
Yes, there are some combinations of amps that are synergistic...or not.
As an example I had experience with; the NAD C356BEE amplifier has been written up as an excellent one, and the PSB Image T6 speakers are very good speakers (I had them for a couple of years), but that amp and those speakers did not work well together; the sound quality was not the best. There was some sort of mismatch there. That sort of thing can happen.
Certain speakers are a difficult load at certain frequencies, and that may cause some amplifiers to misbehave and sound less than wonderful.
I would not recommend the KEF 3005 setup because from my perspective it has front speakers that are too small for adequate performance. I think that front speakers should always be big enough to give you full output down to 50-55 Hz, and then the sub should go down from there only and NOT be operated much above 50 Hz.
In KEF speakers I would suggest that you get a pair of C3 speakers, a pair of C1 speakers, and a C6 for the center. In US dollars that would cost around $850, so that is maybe 500 pounds in the UK? That would be a very nice system; much better-sounding IMO than the 3005.
The Dali Zensor 5 setup is also well-balanced with those requirements in mind.
A subwoofer should have at least a 12-inch driver and 250 watts of RMS power minimum; if it does not meet those requirements it is unlikely to be of much use.
Edited by commsysman - 7/2/12 at 2:09pm
  Back to Forum: Speakers
