AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Runing RG6 next to Romex (electrical power)?
post #1 of 2
I'm fishing wire through the walls. The floor joists under the living room have a hole in it with just enough room for me to feed RG6 for the sub-woofer sitting behind the couch.
How bad is it that Romex is sharing the same hole as RG6? How far apart should they be?
Trying to make things all nice an tidy so the girlfriend will be happy but the way the house is laid out this is NOT easy. And I really don't want to drill any more holes in the floor joists.
post #2 of 2
Not an ideal situation, but you can run your RG6 next to the Romex without trouble.
  Back to Forum: Home A/V Distribution
