AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Good Inexpensive HDMI Matrix
post #1 of 6
Forget the splitters, I need a 8x8 HDMI matrix. I will likely run analog audio separately if I need to for remote sources, but expect most of my sources to be local, so no need for digital ins/outs or cross format conversion.
My need is that it will properly handle all HDMI signals I throw at it (including 3D and HD audio) and will output across all output simultaneously without issue.
I do NOT want flicker from the displays when a TV is turned on or off, or when a new source is added within a valid resolution.
So, if my 1080i cable/fios/sat box is on, and I turn the family room on, then I turn on the basement, my family room should not 'flash' or lose image because I added a new display to the matrix.
If my 1080p 3D source is turned on in the 3D compliant family room, but then turned on in the non-3D compliant playroom, I can handle it doing a resolution shift to 2D and 1080i. No big deal.
Any input is appreciated and I'm trying to keep it under $3,000 if possible. Would like to know the experience others have had with products they may have tried.
post #2 of 6
Try Snap AV, I know they make an 8x8 matrix but I don't know if you will be able to stay within your budget. I had a friend who purchased their 4x4 matrix with HDMI + CAT5e/6 outputs and it went about $1.4K.
post #3 of 6
Good luck. How much money do you have to spend? Have you looked at the Atlona HDBaseT products?
post #4 of 6
The SnapAV 8x8 w/ mirrored CAT6 outputs retails for $5999.99 with the receivers at $149.99 each. The standard 8x8 is $3999. I believe Atlona's 8x8 only has CAT6 outputs and the receivers are $249.99 each with the matrix at $7499.99
post #5 of 6
Snap AV HDMI matrix switchers are very good but have a loud fan
also check out the new Gefen Toolbox GTB-HDFST-848 which lists for $2500.00 and can be purchased for under $2k: no fan and fast switching using FST setting
RT Com makes an excellent 8x8 matrix switch for around $2.5k that has an Ethernet GUI in addition to RS232 and IR control
post #6 of 6
Just catching up on some old posts and wondered if anyone found or could PM me a link to the RTCom matrix for $2500. I am only seeing $5-6K.
  Back to Forum: Home A/V Distribution
