AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Starting from scratch - wiring
post #1 of 2
After four years of being in my house, I am finally getting around to doing the basement which will have a darkroom, exercise room and a theater. As funds are tight, I will not be able to equip the theatre right away, but I want to do the sound proofing and wiring.
The room for the theater is 15x13 with 8 foot ceilings. I plan to use a ceiling mount projector and I can fit a 100 inch (wide) screen. I will use cat6 wire to run the hdmi to the projector. I will also make sure there is a power outlet in the ceiling. Not knowing what projector I will be running, is there any other type of wiring I should run to the projector?
post #2 of 2
I would run 4 or 5 cat6 cables. Powerbridge for power. 2" or larger conduit.
