Originally Posted by TMcG
What I meant by expensive and proprietary is that each company produces keypads that only works with their system. Niles, for example, makes a component called a ZR-6, that sells for about $2300. The minimum keypad cost is $110 per room and the maximum is about $250 per room for one that can receive metadata. So you are looking at $3K on the low end and $3800 on the high end for such a system. And with the exception of the top-end keypad, it is extremely difficult if not impossible to control the system outside of on/off and volume up/down when you have a system based on streaming content.
Well, the cost of an iDevice to leave in each zone for similar accessibility is ~$200/zone... And yes, some systems more open than others. My NuVo shows excellent metadata on streaming sources (from their server product, of course), and I've added my own stuff for some non-NuVo sources using their API...
Hopefully we'll see more "open" keypad / control panel devices in the near future, although the equivalent of a wall-mounted iPod is not what I'd want. To do it correctly, there needs to be a "single app", which has required either high-end custom work or "proprietary" stuff (I don't like using that word in this context - the keypads are part of a single product)...
But yes, as long as the wiring is in place, pick and choose your solution!
Jeff
