Thanks for the info, I have a Panny 65vt50 and it does have an optical out but I couldn't find any headphones that use that connection, everything I've seen has the analog out and I can't connect those to this TV. Plus, I need it to hook-up to the TV and the DVR. Kinda' sucks to get a high end TV only to find that there are no headsets out there that will work.
I've been using Senn 120's forever and have two receivers, one plugged into the DVR and one in the 400 DVD carousel and I was able to switch channels on the headset between the two, so that has worked great for many years until the recent upgrade.
Just checked out the link in post #3 though and see that that set offers the digial out. More than I was wanting to spend, but worth it if that will solve my problem. Does anyone have a set of the Sony's that they use on more than one input?
