Hi everyone...I believe I've norrowed my research down to two receviers, RX-A720 and Denon 2113CI. I'm struggling which receiver to go with. I currently have an older Denon and have had zero problems with it. I'll be connecting this to 5.1 with samsung 3D TV. Is one easier to set up than the other? Does one support video better than the other? I'm interested in playing songs via iPad? Does one have an app that's better than the other? Thanks for an thoughts you have in helping me make this decision.
AVS › AVS Forum › Audio › Receivers, Amps, and Processors › I just can't decide: RX-A720 or Denon 2113CI?
Featured Stories
Topics Discussed
Related Forum Threads
- Denon 2113CI problem Last post on 5/6/13 at 12:56pm in Receivers, Amps, and Processors
- help with denon avr 2113ci Last post on 4/29/13 at 4:09am in Receivers, Amps, and Processors
- Incredibly Frustrated: Please assist with "Zone 2" setup (Denon AVR2113CI, Niles SSVC-4 ) Last post on 4/29/13 at 6:22pm in Receivers, Amps, and Processors
- Denon 2113CI External/outboard DAC Last post on 4/22/13 at 4:59pm in Receivers, Amps, and Processors
- denon avr-2113 problem with network channel Last post on 4/20/13 at 12:43am in Receivers, Amps, and Processors
Gear mentioned in this thread:
post #2 of 13
7/4/12 at 2:52pm
I'm struggling on my decision too. If I get a Yamaha it will be the RX-A720 because the RX-V line such as the RX-V673 has to have the same audio source as the main room. Even the RX-V773, which has a 2nd HDMI out, has to have the same source.
The recurring opinion I see here is that Audyssey of the Denon's is superior to the YPAO of the Yamaha.
Spaznik posted in my thread with the following:
Also I think the convenience of on the fly switching between 7.1 and 5.1 with powered zone 2 stereo is really nice on the Yamaha. On the denon you have to wire it up for one or the other and go change the wires to change setups. The Yamaha just changes where the last two amps send their power based on the situation. That seems great because it allows for 7.1 and powered zone 2 sound without an external amp or second reciever.
This isn't so much of a deal breaker to me. I currently only have a 5.1 setup in my living room. I'm still up in the air.
post #3 of 13
7/4/12 at 4:29pm
post #4 of 13
7/5/12 at 5:07am
post #5 of 13
7/5/12 at 7:40pm
- afrogt
- Trader Feedback: 0
- offline
- 19,877 Posts. Joined 7/2003
- Select All Posts By This User
post #6 of 13
7/6/12 at 9:56pm
- OldSchoolMETAL
- offline
- 404 Posts. Joined 11/2011
Really, I've had nothing but problems with Yamaha receivers. I bought the RX-A710 and had all kinds of HDMI handshake and HDCP problems. Exchanged for a Denon AVR-2312ci and have none of those problems now. Yamaha is known to have HDMI handshake problems with other equipment so it's best to make sure through searching they are compatible.
I wouldn't even consider a AVR-**13 model Denon. This years models take so many features away it's nuts. They only gain a few things but give up so many more. The Yamaha RX-A720 doesn't give up anything and would be my pick but that's only if they have resolved the HDMI issues.
Other makers have also done a lot of give aways with their new 2012/2013 model line, and is why I searched out a 2011/2012 model made by Denon.
post #7 of 13
8/27/12 at 11:45pm
I can add three things to this conversation. First, the weight of each product is very different. The Denon is a mere 22 or 23 pounds. The Yamaha is more. I don't know a lot, but I think the weight of the receiver means something . . . heavier being better..
Second, the app for Yamaha is pretty damn snazzy. Airplay works with the Yamaha in zone 2 as well.
Third, and most importantly, customer service for Denon is very poor in comparison to Yamaha. I was trying to make the same decision with these two models and some guy with a four letter name (Chad?) who worked for Denon actually hung up on me! Then as lack-of-luck would have it, I got him again when I called back and even a third time later on. He was terribly rude each time and it was obvious he did not like his job. Imagine if you need technical support and you have to talk to someone who hangs up on you and treats you with disdain. I chose the Yamaha for that reason. I will never consider a receiver made by Denon or their parent company again.
post #8 of 13
8/28/12 at 3:38am
- jdsmoothie
- AVS Addicted Member
- offline
- 34,418 Posts. Joined 9/2007
post #9 of 13
9/2/12 at 3:28pm
Not based solely. There were other considerations, that idiot just made it easier to decide. And I'm very happy with my choice at this point. It's been a couple weeks and I've gotten everything to work with the help of CSR's. I've had very good customer service experiences with Yamaha which sincerely made for a very positive experience.
If I have to call a CSR for help I don't want to be condescended to or otherwise be treated poorly. That's human nature. I'm glad of my choice and the Yamaha is fantastic.
post #10 of 13
10/25/12 at 10:16pm
Yamaha easily lets your stream from Android devices through its controller app. Not just Airplay. Yamaha has an audio output to expand a main zone with an additional amp/receiver. You have to get the 3313 $1000 in Denon to get an audio output. Yamaha 773 and 820 and above will send digital sources to zone 2 in party mode. Denon requires you to duplicate digital sources with analog for zone 2, until you get to +$1000 models. Yamaha has 12V trigger out on its mid priced receivers vs. +$1000 for Denon. Yamaha can go in standby if left on for 12 hours without activity, Denon will only go for about an hour. I've had lots of quality control issues with Denon's, even ci.
post #11 of 13
10/26/12 at 3:58am
- jdsmoothie
- offline
The 2313CI model (MSRP $849) actually features an analog output and a 12v trigger, although all of the CI models feature a Zone 2 pre-out which can also be used as well to expand the main zone audio. It's not that inconvenient to add an analog cable to an HDMI source to pass the audio to Zone 2, especially considering the vast majority of AVRs require this configuration. Also, I think most would agree they'd prefer to have the AVR shut down to Standby sooner rather than later with no activity ... why wait 12 hours?
post #12 of 13
3/24/13 at 8:46am
post #13 of 13
5/15/13 at 8:23am
- bassage
- online
- 281 Posts. Joined 10/2002
What exactly did they take away?
- I just can't decide: RX-A720 or Denon 2113CI?
Currently, there are 1008 Active Users
(128 Members and 880 Guests)
Recent Discussions
- › How do I get BBC iPlayer for my LG Plasma Smart TV? 5 seconds ago
- › The "official" Yamaha RX-V673 thread. 7.2-Channel Network AVR 37 seconds ago
- › plasma....it's just not that good. I'm not trolling! 56 seconds ago
- › Do I really need Expensive Speakers for Home Theater? 1 minute ago
- › How can I get my kuro 60" fd-150 repaired??? 2 minutes ago
- › Darbee vision darblet 3 minutes ago
- › Samsung hp-r4252 screen problem 3 minutes ago
- › Recommendation on choosing a center speaker 3 minutes ago
- › NEW Unofficial Blu-ray Audio and Video Specifications Thread 7 minutes ago
- › Official Vizio M-Series Razor Mxx1i thread 9 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
