AVS › AVS Forum › Audio › Speakers › Comparison, Unbiased Review & Ranking of 12 High-End Home Cinema Audio Systems
Comparison, Unbiased Review & Ranking of 12 High-End Home Cinema Audio Systems - Page 3
post #61 of 388
Originally Posted by madboynutter View Post
But you didn't answer it correctly, which proves you haven't read my report properly.
In short, the reason why Steinway Lyngdorf is superior in audio quality is because Steinway Lyngdorf audio systems operate differently to all other audio systems. In all other audio systems the digital signal is converted to analogue at the AV Processor / Receiver stage, degrading the signal quality, and then amplified in the analogue domain, which contaminates the audio signal with noise and further degrades the signal quality; whereas with Steinway Lyngdorf the audio signal is maintained as a full resolution digital signal throughout the electronics, meaning it eliminates all the audio quality degradation caused by the way conventional-type audio systems operate.
Elimination of audio quality degradation + elmination of noise introduction = Superior audio quality. QED. cool.gif
You can quite literally turn the volume knob up to maximum and put your ear to any of the speakers and you will hear absolutely no background noise whatsoever... no hiss, no hum, nothing. How many other audio systems can you say that about, eh? smile.gif
And how many other audio systems have 100% eliminated the audio quality degradation caused by converting the digital signal to analogue at the pre-amp stage and then amplifying in the analogue domain? That's right... NONE. wink.gif
Actually, they're not the only ones who have done it this way.
post #62 of 388
Is that older setup all M&K speakers? I am guessing maybe S-80's or S-85's? If this is the case then they did have a horizontal speaker designed as a center. If I was as successfull as you say why limit yourself to the S-150's when M&K had better HT and musical speakers in their own line up? I am not sure what your tastes are in HT but goin from room to room will only show you the best room and best calibration per room, not which speakers are better. Just too many variables with different rooms. I have visited countless showrooms with the apex being a full McIntosh system costing well over $500K but I never use it as a reference point because I do all my comparisons in my purpose built theater. I know you love M&K but I have tested many systems that can beat it for less, the same, and slightly more these days. My M&K system was one of their best ever produced. Times have changed even though I still like that system.
post #63 of 388
But you didn't answer it correctly, which proves you haven't read my report properly/quote]
It doesn't "prove" anything. Your question asked why is Steinway Lyngdorf superior. We do not know that they are. All we have is your opinion stating so.
You still haven't answered my question concerning Audyssey and the very odd speaker placement. Why would Audyssey work better in your system with the speakers placed as they are?
I understood this when I read it in the review, and they are not the first to handle the signal this way. This also doesn't automatically make Steinway Lyngdorf create sound in a superior fashion (except in your opinion) to all others, but thanks for the explanation.
post #64 of 388
Originally Posted by shadyJ View Post
He won't be back; his bluff has been called. Also, I don't think he should be given any credit whatsoever for his comparison. I doubt he heard all of the systems he claimed to, and more likely he heard none. Think about how difficult it would be to hear all of those high end setups in the UK- they wouldn't be very common or easy to hear in any US locality, let alone England. I'm guessing he looked at the specs and designs, and extrapolated from that any possible shortcomings that could be used against them (all horns are honky!) in order to promote his steinway products. I don't think it should be wrong to come in here and promote your products, but I do think it's wrong to misrepresent yourself as an impartial seeker of audio perfection in doing so, and its especially wrong to trash a bunch of other products which you have never heard in the process.
Firstly, you clearly haven't read my report properly. I don't just speak well of Steinway. I clearly state that the best audio system you can buy for £18,000 is MK Sound. I also clearly indicate that the best horn-type audio system is PRO Audio Technology, and the best conventional-type audio system with regards to audio peformance is Wisdom Audio. Furthermore,I clearly state that PRO Audio Technology, which are 'Horns' do NOT suffer from the 'honkiness' that typically plagues horn-type speakers, which basically means that your statement that I "extrapolated from that any possible shortcomings that could be used against them (all horns are honky!)" is wholly incorrect.
Furthermore, you have gone on to falsely accuse me of "misrepresent yourself as an impartial seeker of audio perfection in doing so, and its especially wrong to trash a bunch of other products which you have never heard in the process" when I AM an impartial seeker of audio perfection, regarding which I believe I have now imparted sufficent information within this thread to demonstrate this, and I HAVE auditioned these audio systems.
To audition all these audio systems is very easy and you don't need to be a rocket scientist to figure out how... for example, go pay a visit to Genesis Technologies demonstration centre in Bracknell, England and you can audition the PRO Audio Technology and Wisdom Audio systems (ask to speak to Neil Davidson); go visit Artcoustic UK in Chelmsford Essex and you can audition their home cinema system (ask to speak to Paul Cummin); go visit Gecko's demo rooms in Newbury, Berkshire, and you can audition the Steinway Lyngdorf, MK Sound and James Loudspeaker systems (ask to speak to Rob Sinden)... and so on...
Furthermore, when you've been into AV for over 20 years you tend to develop relationships with AV equipment suppliers wherein they are happy to let you demo equipment. I happen to have the KEF speakers still sitting in my lounge, since they were the last that I auditioned. I will happily have someone take a photo of me standing next to them tomorrow and post it here if you like. Would you like me to do that for you Mr Doubting Thomas? smile.gif
Next time I suggest you get your facts straight before falsely accusing a complete stranger of doing something he hasn't done and unjustly criticising him in the insulting manner that you have. wink.gif
post #65 of 388
You appear to be incapable of reading properly. I have NEVER stated that Audyssey will work better in 'my system' with the speakers placed as they are.
I believe you are now being deliberately obtuse. I suggest you re-read my previous posts, wherein I have already answered this. I am not going to repeat the same information. Furthermore, you are going waaaayyyy off topic mad.gif
Please kindly confirm which other brand operates the same way as Steinway Lyngdorf. smile.gif
post #66 of 388
Originally Posted by Aknot5 View Post
Assuming it had any to begin with, the review lost all credibility when I started reading systems like JBL's Everest were causing "ear fatigue" at reference levels..
JBL's Everest sounds bright and it's harsh when played at reference levels. Harshness = Ear Fatigue. QED. wink.gif
And it costs £1/4 Million eek.gif
post #67 of 388
Originally Posted by NewHTbuyer View Post
Your second post directly implies he has commercial connections.
Let me make my meaning clear to you. It is my opinion that the OP, who has posted this in 3 different forums, is not new to audio boards in spite of his extremely low post counts. He may even have other user accounts, who knows? Another user account that comes in and sticks up for him, who's to say...
post #68 of 388
I think everyone, including myself, should have just said from the beginning, "Cool, that's your opinion", and be done with it.
It's just another one of those "my speakers are better than your speakers" posts. Nothing more.
post #69 of 388
the report is baloney.
the joke is on all of us for even discussing it.
i used to like the company, but now i just have this 'lyngering' bad taste in my mouth like i burped up a turd.
the part where you give the jbl synthesis a 3 rating on a ten point scale for "VOLUME CAPABILITY" and the little l-thingy a 10 is so rediculous that it blows the whole report.
the l-thingy has a 5.25 woofer. the jbl everest has two long throw 15's. that is about a 25db difference in spl capability in the mid bass.
shame on you and shame on lingy for letting you get away with this.
post #70 of 388
If you would answer the questions instead of stalling and going in circles we could steer this thread back on topic. Honestly, I don't believe you have an answer for my speaker/Audyssey question, so feel free to move on.
post #71 of 388
Originally Posted by ack_bk View Post
I tried to read the reviews with an open mind, but it was hard to take the reviews of horn loaded tweeters seriously when he/she kept referring to "honky" sound and basically dismissed all horn loaded tweeters, especially for home cinema where I find they tend to shine... There just seemed to be way too much personal bias thrown into the reviews and it was obvious the review had written off horn-loaded speakers right away. I have heard a variety of horn loaded tweeters (including some mentioned in this review) and "honky" and "inaccurate" is not a word I would use to describe them at all and could be more a reflection of the room and the bias of the reviewer.
You haven't bothered to read my report properly... it you had you would have noted that with regards to my review of the PRO Audio Technology audio system, which comprises horn-type speakers, I state the following:
"It’s horns Jim, but not as we know it… PRO Audio Technology’s flagship home cinema audio range seemingly offers all of the benefits associated with horn-type speakers, including high speaker sensitivity, excellent clarity and good dynamics, but without the usual negatives, such as ‘honky’ coloured and inaccurate sound, and harshness. In fact, somewhat uniquely, I actually completely forgot that I was listening to horn-type speakers. PRO Audio Technology have achieved audio excellence using horn-type speakers, and eliminated the acoustic flaws that typically plague horn-type speakers, where even the most expensive home cinema audio systems, such as JBL Synthesis, have failed. This achievement in itself is nothing short of miraculous."
So please explain, how exactly is this dismising all horn loaded tweeters? Or writing off horn-loaded speakers right away? Oh that's right, it isn't. tongue.gif
post #72 of 388
If you go back and read my posts properly you will note that I state that my brother invented an audio technology practically identical to Audyssey DSX, over 20 years ago, which he called "Panoramic Audio"
Panoramic Audio entailed unusual speaker placement in exactly the same way as Audyssey DSX entails unusual speaker placement.
You criticise me by stating Panoramic Audio's unusual speaker placement is wrong and hurl insults at me about it...
...in which case you should go and do the same to Chris at Audyssey. Well go on then, send him an email to Chris at Audyssey telling him his speaker placement is wrong and hurl insults at him! tongue.gif
post #73 of 388
- The Procella 815 15" 3-way, with 8" mid and 1" CD gets a 2 out of 10 for "volume capability"
- The Everest 6600 system with dual 15" woofers, and a 4" mid CD gets a 3 out of 10 for "volume capability"
- The Steinway S-15 with a single 5.25" mid-woofer and a AMT tweeter gets a 10 out of 10 for "volume capability"
It is clear that you have no technical knowledge as you have ignored every technical question, and simply talked around when people question you. Yes you are obviously wealthy, and likely auditioned all of these speakers, sure you like the Steinway the best. That could have been your entire OP, no argument would have come.
post #74 of 388
Actually, I haven't participated in any AV forums to date because of all the politics, petty insults and jibes, and general childish behaviour. Because it's the Internet it is impossible to maintain an intellectual discussion.
So far, everyone is doing a spectacular job of proving I was absolutely right to avoid these forums like the plague, so don't expect me to be around for too long wink.gif
post #75 of 388
Look, dropping words like "Panoramic Audio" does not tell us how it works. Maybe turning the speakers around to face the wall improves the sound even more? tongue.gif I don't know, and frankly have lost interest in finding out.
Why would I do that? He is a respected member in the audio community with a proven track record.
post #76 of 388
You have failed to read properly my definition of "volume capability" and have incorrectly concluded that woofer size or power handling is singularly responsible for a system's volume capability.
Consider this, if an audio system sound's HARSH when played at reference levels, that means by definition its audio performance is degraded and as such it's volume capability is POOR.
Rule of thumb, if you have to turn the volume down because the audio is grating on your ears then the systems Volume Capability, (i.e. the volume at which you can listen to the system), is POOR. Get it?smile.gif
The JBL Synthesis Everest system is bright and sounds harsh when played at reference levels, therefore I'd have to turn the volume to below reference levels to be able to listen to the system without onset of ear fatigue; therefore, its Volume Capability is POOR, hence the low score.
The Procella Audio system distorted when I played Dire Straits SACD; hence, again I'd have to turn the volume to below reference levels to be able to listen to the system, this time to prevent distortion from occurring; therefore, its Volume Capability is POOR, hence the low score.
The Steinway S-SERIES System could be played at up to and above reference levels without any degradation in audio quality whatsoever and no ear fatigue whatsoever; therefore, its Volume Capability is PERFECT, hence the maximum score.
Edited by madboynutter - 7/6/12 at 7:19pm
post #77 of 388
Ah, sorry I forgot you only like to insult complete strangers for no reason whatsoever wink.gif
post #78 of 388
post #79 of 388
I understand that you like the sound of the Steinway, everything else is purely subjective. Since you have so much money, time, and knowledge, some distortion measurements of the speakers in question would be pretty telling wink.gif
post #80 of 388
No, what you should learn is that volume displacement* determines SPL and that larger drivers can do it far more easily as they must excurse less. For a given motor design, distortion increases with increasing excursion and between motor designs the transfer function may vary markedly. JBL have several decades of motor research behind them and the Differential Drive in the DD66000 is a very highly advanced design. So, even if the SL used as motor design as good (and I doubt it) for a given SPL and frequency (lets say spectrum half power point of circa 250Hz), then the JBL will be excursing considerably less and producing lower THD. The lack of 'volume capability' you give a large powerful and capable system is actually most likely a preference for distortion and thermal compression that a small system will have, and a well designed and implemented large system will not.
* Vd is determined by cone area (Sd) multiplied by excursion (Xmax).
post #81 of 388
You have not read my report properly and hence have not understood my defining of Volume Capability.
This is what I state in my report:
"VOLUME CAPABILITY:
This is defined by the capability of the respective audio system to consistently maintain the same quality of audio performance across all volume settings up to, including and beyond Cinema Reference Levels. You may ask “Beyond Cinema Reference Levels? Why on earth would you ever want to listen to audio at above Cinema Reference Levels?” Well the answer to that question is quite simple, namely that it is important to consider the volume threshold at which the audio quality begins to deteriorate, since this will be representative of how much headroom (if any) the particular audio system has when played at Cinema Reference Levels; and if a particular audio system has a decent amount of headroom when played at Cinema Reference Levels then it will tend to perform consistently better and with more stability than an audio system which is maxed out at Cinema Reference Levels."
Therefore, the dimensions of the woofer is not the singular factor, nor even a key factor, which determines a speakers Volume Capability.
An audio system's defined Volume Capability is the volume threshold at which audio performance begins to deteriorate.
Hence, if an audio system sounds harsh when played at reference levels, then the harshness means degradation of audio quality, and means that you would need to reduce the volume below reference levels in order to listen to it without onset of ear fatigue, and hence the volume capability is POOR, hence the low score.
The "l-thingy" (Steinway Lyngdorf S-15) has a 5.25 woofer" and can be played up to and above reference levels without any degradation in audio quality or ear fatigue whatsoever. Hence the perfect score.
What did you think of my conclusion that MK Sound is the best home cinema audio system that you can buy for £18,000? smile.gif
post #82 of 388
No one understands this. Did you audition the S-15 in a broom closet?
post #83 of 388
1) RE: "your lack of identity is a real problem" - My identity is not a problem as this thread now contains a lot of information about myself that demonstrates that I do indeed not have any affiliation with any brand of A/V equipment. wink.gif
2) RE :You do not say what expertise you have in audio - I have stated what expertise I have in audio, namely circa 20 years experience stemming from a childhood interest in high-end music hi-fi to present day obsession with home cinema, including designing and building home cinemas. smile.gif
3) RE: "You don't say how you came to listen to all of these systems" - Isn't it obvious? In most cases I visited the demonstration centre of the UK Distributor for the respective brand of A/V equipment; e.g. I auditioned the Wisdom Audio and PRO Audio Technology audio systems at the UK distributor’s (Genesis Technologies; Neil Davidson) demonstration centre in Bracknell, Berkshire; I auditioned the Steinway Lyngdorf, MK Sound and James Loudspeaker audio systems at the UK distributor’s (Gecko, Rob Sinden) demonstration centre in Newbury, Berkshire; I auditioned the Artcoustic audio system at the UK distributor’s (Artcoustic UK; Paul Cummin) demonstration centre in Chelmsford, Essex; and so on…Otherwise I audtioned systems whilst visiting the USA or set up and tested at my home. smile.gif
4) RE: "You say nothing about the how limited your aural memory might be, or how it might be affecting your ratings (obviously you want us to believe your memory is some absolute standard of judgement). You present us with the golden ears fallacy when you say you can tell the difference between lossless HD and CD, and then you go on to say CD audio is compressed" - What??? Are you seriously telling me that you can't tell the difference between a CD and a SACD or DVD-A?! Just because I can doesn't mean I have 'golden ears' it just means I'm not tone deaf! rolleyes.gif
5) RE "I like how you mention your favored brand again and again in all-caps; this is a common technique in marketing, so one doesn't forget the brand name" - Oh blimey, here we go! It's a conspiracy! Seriously, you are imagining things. I mean come on! What are you implying? That I am a Steinway marketing agent working deep undercover by infiltrating A/V forums to boost company sales by spelling Steinway Lyngdorf in my posts using CAPITALS as opposed to lower case letters?! Sheez! I won't use CAPITALS any more, happy? smile.gif
6) RE: "I like how you mention your favored brand" - Since I clearly state in my report that the best home cinema audio system that you can buy for £18,000 is MK Sound then I guess that makes my favored brand MK, right? Or is it PRO Audio Technology, which is the best horn-type speaker audio system? Or perhaps Wisdom Audio, the best sounding conventional-type audio system? wink.gif
7) RE: "Any of these would raise red flags for a guerrilla marketer, but taken altogether it looks pretty bad for you" - Hey, watch out, THEY are coming for you! Quick, put on your tin foil hat so THEY can't steal your brainwaves! tongue.gif
300
OK, you have addressed the problem of your identity and have stated how you came to hear the systems you rate, good for you, although you haven't shown anything to back up your claim of being a 'professional' regarding audio. And this still doesn't address the major errors of your comparison which you have neatly sidestepped, namely how it is you have fairly compared the systems in your marketing brochure. You can not fairly compare systems in different room at different times. Room acoustics acoustics have far too great effect on the sound and aural memory is far too fallible for your comparison to be taken seriously, as has already been mentioned. Also, ABX testing has shown that no one can reliably tell the difference between CD audio sampling rates and higher resolution sampling rates ("Audibility of a CD-Standard A/D/A Loop Inserted into High-Resolution Audio Playback". E. Brad Meyer and David R. Moran. JAES 55(9) September 2007)- we can only surmise your super-human hearing is hereditary evidence of your lineage to the planet Krypton. Even more so when you claim to be able to listen to above reference level volumes for prolonged periods with no fatigue.
And if my suspicion of your write-up of Steinway's systems is mere paranoia, why would you write using marketing language and techniques to begin with? Also, it wouldn't be the first time a underhanded marketer has come into this message board pretending to be a disinterested third party doing a fair comparison in order to promote their product, so I am not exactly treading X-files territory like you suggest. To put it another way, if you aren't a shill, then your writing style is truly bizarre, and just how in the world did you think your comparison would be perceived when your written approach to the steinways so closely resembles a late-night infomercial for miracle blades? If you are a shill then you must realize by now how this clumsy attempt at guerrilla marketing has become a liability to steinway, so good going there chief.
post #84 of 388
That must be the answer.
post #85 of 388
And you have also completely failed to take into consideration the fact the audio that is outputted by the Steinway LS Boundary Woofers, which have 12-inch drivers and output audio up to 500Hz. smile.gif
It is interesting to note the vast SPL that can be outputted and with the cone hardly moving at all. Stick Master & Commander Ship Battle on and you are literally lifted out of your seat. cool.gif
post #86 of 388
No, I understood it. It just has no metric or reference outside your head. I also understand the engineering behind the physics of speaker design, which you clearly do not.
According to their website, they are 10" and they will not be able to be used anywhere near 500Hz without localisation issues, except perhaps as stands for the 5.25" thingies, which will undoubtedly not be the right place for them in a typical room. If in doubt about this, research the work of Geddes, Toole, Devantier, Welti etc.
Bollocks. You obviously have very low expectations if that is the case, and you are listening at nowhere near reference.
post #87 of 388
150
post #88 of 388
I have never claimed that my primary profession is in AV. In fact, I have already made very clear that my current business is property development; and prior to that nutritional science.
A/V has been a passion of mine since childhood. Think of it akin to asking someone who has played the piano since aged 7 whether or not they are skilled in playing the piano...
I am not claiming to the the fountain of knowledge with regards to all things A/V related, but I know a lot more than the next guy and I have designed and built countless systems over the years.
Furthermore, I was not aware I was on trial... and hence was not aware that I needed to prove I am a 'professional' regarding audio. I would have thought my history and the report itself speaks for itself.
And to come back to what I have been needing to repeat time and time again, please kindly take it for what it it, namely my opinion; you do not have to agree with it.
It's not like I'm claiming I'm MOSES or anything. Sheez!
How easy for you to criticise my due dilligence exercise and report. Since you are so critical, please kindly submit your report of similar due diligence process wherein you auditioned all these systems in exactly the same room... Oh what's that? You haven't completed it? Well, what about anyone else then? Anyone? Oh that's right NOBODY has to date yet completed such a due diligence comparison. When you HAVE you can criticise. Fair enough?
Do you actually realise the ridiculousness of what you are intimating? The only way to avoid what you bizarrely refer to as "major errors" would be to purchase all 12 audio systems, and then build a house containing 12 identical specially built rooms into which the 12 systems would be installed. And you think that is REASONABLE do you? confused.gif
So instead, you pooh-pooh my effort wherein I have done the best that can possibly be done with regards to minimising influencing factors such as differing volume levels, source material, listening position etc... mad.gif
Are you telling me that you can't remember how an audio system sounded that you have previously listened to? I simply can't believe some of this stuff that's being said here!
And ever heard of TAKING NOTES at the time of auditioning?
Also, ABX testing has shown that no one can reliably tell the difference between CD audio sampling rates and higher resolution sampling rates ("Audibility of a CD-Standard A/D/A Loop Inserted into High-Resolution Audio Playback". E. Brad Meyer and David R. Moran. JAES 55(9) September 2007)- we can only surmise your super-human hearing is hereditary evidence of your lineage to the planet Krypton. Even more so when you claim to be able to listen to above reference level volumes for prolonged periods with no fatigue. .
You need to read the FULL TEXT of that study; which states this:
"virtually all of the SACD and DVD-A recordings sounded better than most CDs— sometimes much better. Had we not “degraded” the sound to CD quality and blind-tested for audible differences, we would have been tempted to ascribe this sonic superiority to the recording processes used to make them."
If you are unable to tell the difference between CD Audio and SACD / DVD-A then I genuinely feel sorry for you.
I wasn't aware that it was! Am I still doing it? I have no idea! Blame my English teacher...
Erm... then I guess my writing style is truly bizarre... or perhaps you are just paranoid and seeing conspiracies where there are none? wink.gif
post #89 of 388
You have never actually auditioned a Steinway audio system have you? Because I know what I experienced when I auditioned the Steinway systems; and the room was enormous too. wink.gif
If you ever happen to pay a visit to the UK I strongly urge you to visit GECKO in Newbury and audition both S-SERIES and MODEL M systems; Rob Sinden will gladly turn the volume ABOVE reference levels for you... as he did for me... and you will eat those words my friend. tongue.gif
post #90 of 388
Have YOU actually ever listened to a Steinway System? Or are you simply passing comment on something that you've never listened to? smile.gif
And that's the whole conundrum regarding the S-15 speaker by the way... they are tiny, yet seem to break the laws of physics... tongue.gif
  Back to Forum: Speakers
