Originally Posted by
shadyJ
I'll just address a few points for those reading, but I don't ordinarily carry on a discussion with those whom I think are arguing in bad faith.
How exactly am I
"arguing in bad faith"???
Perhaps because I am standing my ground and not giving in to the playground bullies?
shadyJ
Here is what you wrote: "my opinion, whilst professional, is entirely impartial and unbiased." You don't have the background to make that claim..
OK let's put this to bed once and for all shall we?
RE: MY PROFESSIONALISM WITH REGARDS TO A/V - My 20 years' A/V experience including designing and building high end audio systems most certainly qualifies me to be able to carry out
reviews of audio equipment. Do you disagree? Please kindly confirm.
RE: MY BEING ENTIRELY IMPARTIAL AND UNBIASED - My name is Nigel; and I am the Managing Director of SCEPTRE PROPERTY DEVELOPMENT LTD in the UK; who's prior business was ULTRALIFE LTD, a manufacturer of Nutritional and Sports Supplements. Hence, I do not sell
any A/V equipment direct to the public, and I have
no affiliation
whatsoever with any specific brand of A/V Equipment, and consequently by definition am indeed of the rare position of being truly unbiased and impartial when it comes to AV Brands; something which I believe CANNOT be said about all those who are doing all the attacking and criticising, such as YOU.
shadyJ
...it is your integrity that I question. I could easily see someone favoring speakers like steinways, but your exalting description is hilariously over-the-top, and is a transparent give to your agenda. Next time you want to covertly sell something, read about this thing called 'subtlety'.
But you know my identity; I have just repeated it for the umpteenth time; so, given I am the Managing Director of a Property Development Business, please kindly explain exactly how I am in any regard a SALESMAN OF AV EQUIPMENT? Oh that's right... I'm NOT.
shadyJ
And while you might not be moses, your comparison reads like you found the word of god and have come down from mount hi-fi to share it with the masses.
Well EXCUUUUUUSE ME for being passionate about home cinema audio quality! Since I am clearly obsessional about home cinema isn't it kind of OBVIOUS that I going to be pretty opinionated?
Furthermore, I will repeat (again for the umpteenth millionth time) that it is
my opinion; you are perfectly entitled to your own that clearly differs. So instead of trying to bludgeon me to death that my opinion is somehow "WRONG" how you simple respect the fact that that I am perfectly entitled to my opinion and let's agree to disagree and shake hands as friends, OK?
shadyJ
Moreover, notes are not a substitute for aural memory, as you well know. Back-to-back A/Bing over the same material is the only way to tell for sure...By the way....
when I did
do a comparison between audio equipment, while I was far from meticulous, it was in the same room, and I was more diligent than to simply rely on notes. Furthermore, I was careful to enumerate the shortcomings of my comparison, of which there were many, including my own biases...
So let me get this straight, you are STILL criticising me for not conducting my auditioning of 12 high-end home cinema audio systems back-to-back and all in the same room???
What exactly does your comparision of a
singular item of AV Equipment with your existing equipment which you conducted in the same room illustrate? I shall tell you... it shows that it is
easy and
simple to conduct a comparison of a
singular itemof AV Equipment with your existing equipment in the same room. SO WHAT? This information is in no way relevant, because it is completely not feasible to do that for all 12 other these high-end audio systems.
But since you will indubitably persist in pursuing this matter Mister All-Negative-Criticism why don't YOU try to do that with all 12 of these high-end audio systems listed in my report and see if you find it so easy, let alone possible... what you will find is that what you are criticising me for not doing is IMPOSSIBLE bar purchasing all 12 audio systems, and because you cannot set up 12 complete audio systems in the same room at the same time, nor quickly enough change equipment over, set it up and calibrate it properly between auditions, to meet your time limit for aural memory, then you would have to custom build a new housing development that contained 12 identical rooms for you to then install all 12 systems; so basically you are looking at a cost into the millions of bucks and at least a years' worth of time. Well I'm sorry but you need to understand that given the circumstances I have done the very best that was possible without going to these ridiculous measures, and hence since you yourself cannot and would not do this you are bang out of order for criticising me as such mister. So I suggest you let this one drop because if you persist in arguing that I should have used the same room for auditioning all 12 systems you will only embarrass yourself further
Edited by madboynutter - 7/7/12 at 2:05am
