I have two Sony KD-34XBR2 CRT HD’s I got free for hauling them away. One works perfect, but the other starts up with no flashing codes and will display only static SD images off a dvd. Once any scene changes or any movement occurs it immediately does a power shut down. I can restore operation by unplugging it for at least 5 minutes and plug it back in. Degauss sound is heard and the screen reappears and stays as long as the scene remains static. The screen is perfect SD except it has massive pincushion both sides. The Sony OEM Service manual describes a Service Mode activate sequence that is impossible to interpret! So I have no way to correct the pincushion distortion from the remote. I checked the V+ and V- wires going to the conversion yoke, no horz or vert waveforms present. Seems there is failure on the “D” deflection board’s pincushion correction circuitry. I might fix this first to see if that solves the non-static video shut down problem, but I doubt it. So any suggestions besides trashing it?………Tom
