Hi all, I'm building a theater room in the basement (link is in my signature). I've been researching WiFi enabled thermostats such as Nest, Ecobee, 3M and want some opinions as to which is best for me. The thermostat will be outside the theater, and it really will only be on when we are in the theater or when we are exercising in another part of the basement in the summer. The basement system is on a damper system with the main floor zone. My HVAC guy is also going to be hooking up a relay between the thermostat and an inline fan which will function as the return vent for the theater. My main requirements are as follows:
1) Controlled by iOS apps (I know they all do this) so that I can adjust temp and turn on/off from the theater or exercise room
2) Can be locked so that my son cannot change the temperature (Nest has a lock range of temp feature which can be overriden by the iOS app, 3M looks like it has a lock feature but can't tell if it can be overridden by the iOS app)
3) Ease of installation - do I need a Control wire for all of these to make it worthwhile? I think (but am not sure) that the relay switch will require a control wire in any case, and running one will not be really difficult as everything is exposed in an unfinished portion of the basement. I have seen some issues with the Nest installation in some reviews - any experience? Can't seem to get much info on the nuts and bolts of installation of the Ecobee but perhaps I need to dig deeper on their website.
Any thoughts? Help is greatly appreciated!
