AVS › AVS Forum › Display Devices › Screens › DIY Screen Section › Screen Help (Paint)
Screen Help (Paint)
post #1 of 17
Hey guys,
I was wondering if someone could guide me in the right direction for painting my screen? Details:
Viewsonic Pro8100 Projector
Screen size is ~120"
Seating is 12ft from screen
Ceiling painted flat black
Ambient light in the room
I read a couple threads and saw people doing a mixture with the behr flat white ceiling paint to get a grey screen... I just want to make sure I have the right color mix for my projector...
Thanks in advance!
post #2 of 17
Need to know the throw distance, but at this conjjecture it's pretty obvious you need more than the 1.0 gain or less a UPW w/Gray would provide to achieve a truly dynamic image. Using a paint that will augment Contrast (...improving Black Levels without crushing Whites...) and provide at least 1.2 to 1.3 gain would be just the ticket. Ergo....RS-MaxxMudd LL
You "can" Roll that particular mix, but spraying is so much better and pretty much assures you that the 120" diagonal image as seen from just 12' away will look pristine.
A excellent Sprayer can be had for under $50.00, and in fact I know of at least one member with a slightly used one to sell.
Post up again if you want to proceed with a course of action that will result in more than you really thought you could expect for the effort and expense you outlay.
post #3 of 17
Hey Mississippi Man!
Thanks for helping a newbie out! My projector sitts directly above the couch. So the throw is at ~12ft. I really have no experience spraying. Would a 1/4nap roller work well?
I followed this guys write up for a diy setup:
http://www.hometheatershack.com/forums/diy-screens/29917-elektra-8-3-120-drywall-screen-pics.html
I am all ready to prime and paint! Then its off to the fabric store to buy some velvet for the screen frame...
post #4 of 17
Are you going to use that paint? Or are you referring to the Screen's construction?
That particular formula is just a odd attempt to copy a older MMudd SE Mix that originated on this Forum, made darker still by adding extra Gray base and it's not as good a performer as you need in any case. RS-MaxxMudd LL will do a much better job. I did not feel the need to move you toward any really advanced formula....and I still don't. But you "DO" need gain as well as at least some modest degree of contrast enhancement.
Good luck on finding a Good Black Velvet locally at even 2x this price. http://www.syfabrics.com/View.aspx/Plush-Triple-Velvet/Black-Plush-Triple-Velvet/681/264
post #5 of 17
Thanks for the quick reply... I just followed that thread for the screen construction... I am all ears on what type of paint I should use. The room is not completley controlled for lighting. I am worried about the ambient light...
I came across your proposed paint:
RS-MaxxMudd
RS-MaxxMudd (for moderate ambient light)
16 oz. Delta Pearl Metallic #02601
12 oz. Delta Silver Metallic #02603
7 oz. UPW flat
4 oz. Delta Pale Metallic Gold #02624
14 oz. Minwax Polycrylic - Satin finish
10 oz. distilled/tap water
RS-MaxxMudd LL (for lower lumen PJ's, and for completely controlled lighting)
10 oz. Delta Silver Metallic #02603
10 oz. UPW flat
2 oz. Delta Pale Metallic Gold #02624
10oz. distilled/tap water
Question: With the Pro8100 projector being rated at 1000 ANSI lumes is it still considered not a bright projector?
Edited by izover4u - 7/6/12 at 12:33pm
post #6 of 17
If your rolling, RS-MaxxMudd LL
RS-MaxxMudd LL v.2.1
(for lower lumen pj's and controlled light home theaters)
20 oz. Rustoleum Metallic Accents - White Pearl
10 oz. Liquitex Basics Silver
12 oz. Behr 1850 Ultra Pure White - Flat
12 oz. Minwax Polycrylic - Satin finish
20 oz. distilled/tap water**
this is the only mix of the rs-maxxmudd family that can be rolled
Here is the link for the RS-MaxxMudd v2 Thread:
http://www.avsforum.com/t/1319717/the-official-rs-maxxmudd-v-2-mix
post #7 of 17
Thanks!!
post #8 of 17
Thanks!!
Natch! Good luck!
post #9 of 17
Originally Posted by MississippiMan View Post
Natch! Good luck!
Hey MississippiMan,
Been so busy I wasn't able to mix the paint till tonight... Is the paint mixure for RS-MaxxMudd LL v.2.1 suppose to be super thin?
I followed your recipe to the "T" I just want to make sure I didn't miss anything:
post #10 of 17
If your spraying, it should be almost the same consistency as thin Tomato soup. When strained through a nylon Sock Filter, it should just fill the bottom of the filter about 1/3rd up, then continue to drain at the same rate you pour the paint in. (...about the same rate you pour out Milk into a small glass....)
The 20 oz of water is almost too much....but not if it meets the aforementioned criteria. If it does seem to filter through too rapidly, simply leave the paint container open about 3-4 hours, stir, the re-check.
Water tends to evaporate out of such mixes pretty quickly.
post #11 of 17
Unfortunately I am going to roll this screen... It just seems so thin to roll. I will leave the container open for an hour or so and see if it thickens up some before I roll the first coat.
Thoughts?
post #12 of 17
Thoughts?
I don't know what substrate your using, but if your mix is really all that thin, and your painting onto a "sheet' of some material, it may be advisable to Roll the screen on a horizontally flat surface. Keep the surface "wet", and don't overwork the paint (...spread it too thinly...) or you will get roller marks.
If the wall is the substrate, follow the same advice only be very careful to not "overload" the roller.
Guy....I know we state that RS-MaxxMudd LL is "roll-able"...and it is, but we are really talking about the lessor chance of the metallics being an issue, not that the paint itself is applicable for most to roll effectively. Unless the prepared surface is very smooth...almost glass-like, and you can use a high quality 9" Fabric (...not Foam) Roller that is specifically made for "Smooth Surfaces (3/16" Nap) (...and have the skill to use it correctly...) it's at best problematical that you'll make it through with no issues.
I'm not one to herald doom and despair, nor advocate that people spend more than necessary, be it time, effort, or money. But a 120" screen demands the best possible effort, and quire frankly, the cost of Rollers, a decent Tray (...they are NOT all the same...) works out to be about 1/2 the cost of a $50.00 Electric HVLP sprayer. That difference can mean the difference between virtual perfection and a real disappointment.
And....the amount of paint you have will barely be enough for three good "Rolled" coats. You don't have much fudge room going for you, and that always pains me to see happen with a member going into what can be and should be...a project with such great potential.. I worry about you guys like a Mother Hen. redface.gif
post #13 of 17
Hey Mississippiman!
Well I finally have my screen frame wrapped and mounted on the screen. Its time to PAINT! I applied a couple of coats of primer (rolled it with a 3/16 nap) no roller marks what so ever! BUT, when I inspect the screen closely I can see orange peel in the primer coat. Of course this is not visible from viewing distance but it is bugging me.tongue.gif So now I am torn and want to remove the slight orange peel before I apply the RS-MaxxMudd LL v.2.1.
I fear that rolling the RS-MaxxMudd LL v.2.1 even with a 3/16 nap will result in a slight orange peel when inspecting the screen up close. IF I spray the paint will the orange peel no longer be an issue? If so, what steps should I take? I was thinking sanding down the primer all the way up to 400 grit sandpaper then spray.
Or
Can i get away with sanding down the primer to get rid of the orange peel before I roll the RS-MaxxMudd LL v.2.1 for the first time?
Thanks again for all your help! I will be sure to post up pictures once I complete this little project.
post #14 of 17
A Sanding of the primed surface using a Large Fine Grit Sanding sponge (...in the Drywall Section @ HD...) until you have smoothed the surface down evenly is all that is required.
Spray instead of Roll? All I can say is that Spraying will always produce the smoothest, most consistent results. One has to really over-apply a "Duster Coat" onto semi-dry paint to get any Orange Peel.
When rolling even a paint that is meant to be rolled, the end result is always wholly dependent on technique (skill) as well as paint viscosity and drying conditions. Sprayed Dusters apply so little paint per coat, (...relying on a gradual layered build-up...) that the finish is almost "Car-like" smooth at close inspection.
With a sanding as described followed with a sprayed application (...5 Duster coats avg.) it's virtually assured that your end result will be as perfect as the Gods of DIY Screen Making will allow. So make a Burnt Offering of those damnable Rollers, genuflect to the No-Name found here ( http://www.ebay.com/itm/GRACO-HV2900-39-CFM-450W-HVLP-House-Paint-Spray-Station-Machine-System-Painter-/230791007590?pt=Paint_Paint_Supplies&hash=item35bc374d66 ) and all will bow to your glorious Screen's visage.
The Grab an Apple, sit back and enjoy.......................................
post #15 of 17
I plan on wetsanding the primer coat tonight. Started this afternoon and did a section and boy does it look and feel like glass! Like i have been reading its all about the prep work!
Thanks again!
post #16 of 17
Thanks again!
Any update or progress here?
post #17 of 17
I wetsanded half the screen to look and feel like glass... Hopefully I will have some time this weekend to finish sanding and prepping the screen.... Not enough hrs in a day! Will keep you posted.
  Back to Forum: DIY Screen Section
