I got TASCAM 144 mk II sound card and calibrated ECM 8000. I am still trying to understand running the EQ wizard software. The connection diagram for Eq wizard says to connect Left or right line output of TASCAM(Sound card) to receiver to test. Sound card only sends output to one channel. It also says I need to put receiver in Stereo mode.
I want to confirm if the following are right to test signal.
1. Assign Aux output to front a/v jacks ( I see Red/white/yelow)
2. Go to setup and change 2.0 source to send as strereo. Is it right since there is only one connection either red or white (Left or right speaker)
3. Anthem ARC to be off.
They want to increase volume in the receiver to get to 75 for levelling and start measuring. Software has option to send to main or main+subwoofer. I am assuming that the signal is wide spectrum in the case of main+subwoofer and Anthem will split the signal to send to main speaker and subwoofer. Not sure how it works.
Not sure if Anthem duplicates signal to both left and right main speakers Or I need to buy some y connector.
Appreciate to confirm my understanding on the receiver settings/connectons to perform test for water fall/RTA/Impulse (first reflections)
