AVS › AVS Forum › Display Devices › Direct View (single tube) CRT Displays › How much input lag, on average, do Sony Wega Trinitron CRT HDTVs have?
post #1 of 3
I'm considering buying one off of Craigslist for gaming. This is in regards to HDMI gaming.
post #2 of 3
Most likely less than what you are playing on now. Unless you are playing on an SD CRT in which case it won't be quite that good.
post #3 of 3
Somebody just made a thread about this a few posts down, look at that. As far as I know, the lag numbers are similar amongst most of their CRT HDTV's
