AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › I'm concidering this HDD as a extra for my 515
post #1 of 4
I'm concidering this HDD as a extra (internal) for my 515. or should I wait till after Summer for lower price?
Thanks STB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136795&nm_mc=EMC-IGNEFL070612&cm_mmc=EMC-IGNEFL070612-_-EMC-070612-Index-_-InternalHardDrives-_-22136795-L0D
post #2 of 4
Latest projections say the HDD supply will not "normalize" until Q1/13. Don't expect prices to budge significantly until then and probably not back to pre-flood levels.
post #3 of 4
What about a Green Drive? Maybe quieter and less heat.
http://www.ebay.com/itm/Western-Digital-Caviar-Green-500GB-5400-7200-RPM-16MB-Cache-HDD-WD5000AADS-/380450638780?pt=US_Internal_Hard_Disk_Drives&hash=item5894a00bbc#ht_1187wt_1270
post #4 of 4
This is the OEM MODEL that is in there
Western Digital AV-GP WD5000AVDS 500 GB Hard Drive Power-conserving WD AV-GP SATA hard drives take advantage of WD GreenPower Technology to meet the extreme requirements of demanding audio and video environments. With power reduction of up to 40%, they deliver cool and quiet operation and reliability perfect for audio video applications such as PVRs, DVRs, set-top boxes (STBs) as well as surveillance video recording.Technical Information
Platform Support: PC
General Information
Product Model: WD5000AVDS
Physical Characteristics
General Information
Product Type: Hard Drive
Miscellaneous
Green Compliance Certificate/Authority
RoHS
Green Compliance
Yes
General Information
Brand Name: Western Digital
Miscellaneous
Weight: 0.97lb
Drive Performance
Maximum External Data Transfer Rate: 300MBps
Compatible Drive Bay Width: 3.5"
Compatible Drive Bay Height: 1/3H
Hot Swappable: Yes
Warranty
Standard Warranty: 3 Year Limited
Interfaces/Ports
Hard Drive Interface: 1 x 7-pin Serial ATA/300 Serial ATA
Drive Performance
Rotational Speed: 7200 rpm
Buffer: 32MB
Environmental Conditions
General Information
Manufacturer: Western Digital Corporation
Manufacturer Part Number: WD5000AVDS
Product Line: AV-GP
Manufacturer Website Address: www.wdc.com
Miscellaneous
Additional Information
Features:
Native Command Queuing (NCQ)
Preemptive Wear Leveling (PWL)
IntelliSeek
SilkStream
IntelliPark
IntelliPower
Form Factor: Internal
Power Description
Reliability
Warranty
General Information
Product Name: AV-GP WD5000AVDS Hard Drive
Software
Storage Capacity: 500GB
Edited by mickinct - 7/7/12 at 10:24am
  Back to Forum: DVD Recorders (Standard Def)
