AVS › AVS Forum › 3D Central › 3D Displays › TruMotion doesn't seem to work in 3D on my LG 55LM7600
post #1 of 6
All levels of TruMotion work as expected in 2D but none of them do anything when playing a 3D Blu-ray. Can a lover of the SOE please look for this and verify? It's an LG 55LM7600.
BTW, i am amazed how few SOE artifacts this set has compared to my 3 year old Sony KDL-65W5100 with Motionflow.
post #2 of 6
Set the truMotion intensity value to the lowest value to reduce artifacts.
Tru motion is not available when in 3D because the TV can not display both screens and insert a black frame( or frame scan) after each frame in 3D and have any time left to insert an interpolated frame even with a 240Hz LCD TV.
post #3 of 6
Thanks. Is that true of all active & passive 3D sets when playing the SOE?
post #4 of 6
That I am not sure of. It should not be a problem on displays higher then 240Hz but may be.
post #5 of 6
As far as i'm aware all of lg's 2010/2011 3d passives was the only passive 3dtv's on the market that had interpolation active in 3d.
I've had a few lg's and a few other passives from other manufactuers, the only reason i go lg for the last few years was because of motion interpolation in 3d wink.gif.
Maybe lg have messed up, maybe you need to change settings in 3d, dno.
I do know i was looking at getting the uk's counterpart this weekend so this news is disturbing if it is'nt a user error or firmware error.
post #6 of 6
I'll check tomorrow & make sure mine has the latest firmware/software updates and report back.
  Back to Forum: 3D Displays
