It wont display anything anymore.
HD61LPW62
I had an upscaling dvd playing connected via HDMI previously. The DVD player only upscaled, to 720 p, through HDMI. Suddenly the HDMI stopped working. It didnt work for the DVD player, it didnt work for xbox. I figured it was an HDCP handshake problem. I did the turning everything off trick. I turned things on in every possible combination. No luck. I changed HDMI cables a couple of times. No luck. This was a couple of years ago.
So I have not watched DVD's for a couple of years. Cable is hooked up through component. For Fathers day this year, the kids got me a blu ray player. It only had a HDMI connection. Same problem. I went online and ordered a Samsung BD C6500 which has component output prior to January 201 encryption change. But they sent a BD D6500. I hooked it up via component anyway. It did not work and interfered with the cable tv component connection, and now it doesnt work at all. So now, no component connection through either input, and no HDMI. Its useless now, but what the hell is going on?
HD61LPW62
