Originally Posted by mesostinky
Wilkcards, a couple of files for you. I'm sure they exist on AVS elsewhere as well. Don't know if you'll find it useful or not. One is the RS232 and IP commands for Custom Installers for the VSX-1120-k and Two is a plugin from for a program named Indigo which is a home automation program . This plugin is specifically for the VSX-1122-k and I found it on their forum here http://www.perceptiveautomation.com/userforum/viewtopic.php?t=8737
Anyway for whatever it's worth.
pio-rec-vsx1120k.zip 564k .zip file
Pioneer-Receiver-1.0.zip 44k .zip file
Thanks! I actually found both of those in my research and they are very helpful. Apparently these is some documentation on the specific commands for the vsx-1122k, but I haven't been able to find it yet. Most of the commands seem to be the same across all pioneer receivers, though.
even if that could work, that is a poor way to implement a home network
if it does, then reboot the phone. I've found that rebooting the phone & re-launching the app restores lost connectivity. don't ask me why this happens, 'cause I don't know
