AVS › AVS Forum › Audio › DIY Speakers and Subs › Does ABS Glue ruin speakers?
post #1 of 2
I'm using the glue to hook up the internal flared port past the fitted brace - must be done in-box.
Do you have to wait 24 hrs like you do with silicone?
post #2 of 2
No, as it doesn't outgas over a number of hours like silicone does.
