AVS › AVS Forum › Other Areas of Interest › Camcorders › Sample Video Canon HF M50
post #1 of 5
Went to SeaWorld in San Antonio Tx for the 4th . Here is a short sample video for the HF M50 . Hope you enjoy it ! BTW this is a quick throw together . Other than adding titles at the beginning and end i did no other editing .
http://www.youtube.com/watch?v=tTqXL6ek1cY&feature=plcp
Edited by ronlhodges - 7/8/12 at 7:14pm
post #2 of 5
Colors looks excellent. Steadiness seems fine while zoomed out but gets worse when zoomed in. A monopod would probably go a long way to smoothing things out. Also not sure why the video is cropped like that, but otherwise some pretty solid pq.
post #3 of 5
Thanks for the comments . Has to be something that YouTube is doing for presentation cause it should not be cropped at all . I've noticed other videos i did are the same way . I switched back and forth on the large player and small player and both do the same thing and the same thing on the HD and normal settings . I just noticed that early this morn , last night after i uploaded it was not like that . I've checked the settings but since i'm doing the free side there isn't much settings to switch so unless you might know what YouTube is doing i have not a clue what it causing the crop . ???
post #4 of 5
What are you using for editing software?
On edit, I saw on YT you put a Premier Elements 10 tag on it. I should have remembered.
PE10 gives you two choices. One is to Share>Online>YouTube and there are about 8 preset choices.
I use the other. I create a file optimized for YouTube. Do Share>Computer>AVCHD where there about 25 presets, including one for YouTube HD. That puts a file on my computer and I use the YouTube uploader. It may take longer, but I've had good luck with it.
Bill
Edited by bsprague - 7/9/12 at 10:09am
post #5 of 5
Bill
Yes PSE Premiere 10 is correct . I'll give it a try with your suggestions . I usually just do share>YouTube.YouTube HD 1440x . That maybe the problem right there .
  Back to Forum: Camcorders
