AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Distance from Seating to Screen size
post #1 of 10
Hey Guys, just wondering, in terms of screen size to sitting distance, what is the recommendation? Or is there a standard or something?/
post #2 of 10
There are some calculations made such as this one for THX
http://www.thx.com/consumer/home-entertainment/home-theater/hdtv-set-up/ .
But some prefer different, I sit roughly 7ft from my 100" diag screen which is close to even THX calculations. But some choose to sit further away.
post #3 of 10
Screen width X 1.5 = seating distance. EX: 8' wide screen(110") X 1.5 = 12' seating distance.
post #4 of 10
There are guidelines, but ultimately it comes down to preference - hang a sheet for a temporary screen, and project onto it to decide what size you like, before ordering your screen.
I'm 12' from a 136" wide 2.125:1 aspect ratio screen, so I'm on the "I like immersive" end of the spectrum.
post #5 of 10
Thanks guys. I was looking at about 106" from about 15-16 feet away. That should be good enough. Cant fit a bigger screen.
post #6 of 10
That will be fine. The old rule was twice screen width, then we got HD and it came down to 1.5 screen width. I sit at almost 3 times screen width, and while it isn't as immersive, I think how much better the 80" wide screen is than a 40" LCD would be (I can only fit an 80" screen by using a pull-up model , and a 40" would be the max permanent TV I would be able to put in the living room without blocking dining room entry.)
post #7 of 10
I love this site: Plug in the distance you are away from the screen and it will give you min and recommended screen size. This is based on a theater experience! This has been very helpful. If you are only 10 feet away from the screen like my room....you don't want a 120 inch screen...it would be ridiculous like sitting in the front row of a movie theater. For my room it said it recommended an 89" diagonal (Min 73") and I'm at 84"! It looks great in my room!
http://myhometheater.homestead.com/viewingdistancecalculator.html
post #8 of 10
If that's the biggest you can go...it's a no brainer. I would try to arrange my seating closer. Using the site I posted they reccomend no further away that 13.9 feet away for a true theatre xperience. I'm sure it will be fine!! But arrangements of seating could help!!
post #9 of 10
Thanks for all your help. And thanks for that site. Comes in hamdy. I may try to rearrange things.
post #10 of 10
One additional data point - if you get a screen that's too big, you can move seating back, or adjust zoom and mask it down; if you get a screen that's too small, you can move seating closer, or buy a new screen.
