AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › dependable, simple media player suggestions
dependable, simple media player suggestions - Page 2
post #31 of 34
Originally Posted by sdg4vfx View Post
Sounds like options are:
- $129 can get the Micca 600 or a used PCH A210 that will do BR menus. I'll look those up in the forums.
- Pop Box v8 is also $129 but no BR menu support. (Same price as Micca 600?, but has Sigma chip ...)
Anything worth the upgrade at if I up the price range to $150-ish?
Again thanks!
If you double that you can buy a Dune Smart series. If you go $220 you can buy a PCH-A300. Other than that all you can get at $150 is a Micca EP950, which is the same as the EP600, but you can install an internal hard drive, and it come with a gigabit ethernet port that doesn't support gigabit speeds due to the processor not being powerful enough.
post #32 of 34
Thanks again!
post #33 of 34
Since this is essentially a temporary solution player ...
Going to look for a used PCH A210. If I can't find it I'll give the Micca 600 a try.
post #34 of 34
I might be departing with my 210 so let's stay in touch.
