Finally got everything up and running. Here are a couple pics inside the ML03 (Milo).
The HDD is under the ODD (Lite-On BluRay Burner). Left the SSD on the bracket. All the unused power cords are tucked in between the PSU and ODD/HDD bracket. The 2 Enermax fans are whisper quiet. Honestly the only thing you can hear is the ODD at times. All the fans are inaudible.
Just a note, Ideally I would have put the HDD on the plastic bracket, but it is nearly impossible with the 24pin ATX and USB 3.0 header placement with this board, though it is doable. An HDD (3.5") has to fit slightly under the lip of the chassis in that spot. Board selection is critical if you're going to pack this case full.
Edited by wiley165 - 7/18/12 at 8:35pm
