AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Onkyo 818, 9.1 and buttshakers
post #1 of 3
Hi all,
I am purchasing Onkyo 818 but I'd like to do 9.1. As I understand, I need to buy an amp for that. I also want buttshakers. I believe I need an amp for that too. Questions :-
1) Can I drive both with the same amp? How many channels will I need?
2) Can I use an old el-cheapo receiver instead of that amp? Can this receiver drive both extra two speakers and buttshakers?
3) Which one of above is the better option.
I really want 9.1 (Audyssey DSX setup) but I had my heart set on Onkyo 818. Since I need an amp / receiver for buttshakers anyway, I think I should be okay with an 818 (which is a 7.2 receiver). Not being very technical, I am trying to figure out if I am missing anything.
post #2 of 3
1) Yes, you can use the same amp. It would need to be at least 4 channels if you are adding 2 buttshakers. 2 Channels would be used for the surrounds and 2 for the buttshakers.
2) If the receiver has analog inputs then technically you could use a receiver.
3) If it was me I would purchase a cheap amp over using a receiver.
post #3 of 3
Thank you! Where do I find inexpensive 4-channel amps that can drive my 8 ohm bookshelf surround speakers and buttshakers?
