AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Projectors at CEDIA Expo 2012
Projectors at CEDIA Expo 2012 - Page 13
post #361 of 385
Originally Posted by millerwill View Post
I share your thought about not wanting to limit the 16x9 pic if one chooses a 2.35 screen.
An innovative solution, no reason to artificially limit your options by conforming to any AR.
post #362 of 385
Originally Posted by Toe View Post
Sorry for asking since I am sure this has been covered, but what are the differences between the 48 and 4810?
I believe the 4810 is 3 year warranty and the 48 is two
post #363 of 385
Originally Posted by blee0120 View Post
My HP is electric. I raise it up to eliminate the bars, then raise it back down if the film is in 1.85 or 1.78. Works perfectly for me
A great way to do it!
post #364 of 385
Interesting on the electric screen. Never thought of that. You would only really have to mask the top then if you have this.
post #365 of 385
Unfortunately the sound image does not move up-down with the screen image, a Trinnov processor can fix that.biggrin.gif
post #366 of 385
Originally Posted by Owen View Post
Do you really get up in the middle of a movie to readjust the masking to suit a change in aspect ratio?eek.gif
Of course not.
post #367 of 385
I have an electric screen and could do the same, but the image would just be too high for me, so I shift the image to the bottom then mask the top. More trouble but worth it (I keep telling myself tongue.gif)
post #368 of 385
I'll leave it at this since it is OT.
As far as I am concerned the viewed decides what deserves to be bigger.
Fair enough.
37 degrees is very modest, no wonder you have no issues with the image quality of scope at that viewing angle. I am happy to view 2k scope at as much as 50 degrees for good transfers and 16:9 at even larger viewing angles as its typically higher quality then scope, the size of the image is no problem at all. With higher quality source I would go to 57 degrees for scope without hesitation.
I dont view TV of any kind on a projector, quality BD content only.
I'd actually like to go a bit bigger/wider but the room won't allow it, and I kind of built myself into a corner as far as moving the seating forward. It sounds like you don't actually have a CIW system, it sounds like you have a VIA system like Rich does, so I'm not sure why you're arguing "pro" CIW. But my point was not limited to TV, TV is just an extreme example of the idea that scope content is meant to be bigger than 16:9.
Maybe so, but it is the way it is so I choose to work with what I'm given not fight it. The upcoming 4k format is almost certainly going to be 16:9 along will 4k projectors so it seems Sony and hardware vendors have not leaned anything. wink.gif
I'll be happily running a CIH setup (probably with a lens) when I upgrade to 4K, just like I did when I upgraded to Blu-ray from DVD. Resolution doesn't determine relative presentation IMO.
CIH is a "problem" because video is CIW, some people may not be concerned about this "problem" but others are and I am one. I cant view scope 33% wider than 16:9 because image quality drops too much for my liking.
It might have tradeoffs you don't like, but it's not a "problem".
We only sacrifice impact if the screen is too small. With a suitable screen width for scope some people may find the 16:9 image too big but others wont.
It's up to the individual for sure, but my point, my contention is scope is supposed to be larger than 16:9, with the exception of stuff like IMAX which is in a different category.
We also sacrifice the impact and immersion of quality 16:9 content, thats acceptable to some but not to others and definitely not me.
I think most 16:9 content is not meant to be more immersive than scope.
post #369 of 385
Good point.   I agree that shifting the pic down to line up with the bottom edge of my screen makes for a much more pleasant 2.35 image.  It's also good to have light-absorbing black material below the screen, so that the 'black' (actually dark gray) over-spill (from zooming) is fully absorbed.
post #370 of 385
I don't do any zooming. The 2.35 is just shifted to the bottom of the 16:9, so there is no overspill at the bottom of the screen, just a double sized gray bar above the image.
post #371 of 385
This has me really thinking of getting a electric screen. I was so fixed on a fixed frame
post #372 of 385
I tried shifting to the bottom but it was too low for me, plus I have my screen about a foot from the ground, so when I raise it up, the image is about 1.5ft from the ceiling.
post #373 of 385
Anyone interested in JVC's new projectors, AVS is taking Pre-Orders now and have great prices. Please call one of the AVS sales reps for all the info.
post #374 of 385
Took advantage of it.. Got a Rs46
post #375 of 385
Yeah, the bottom of my screen is about 3ft from the floor. And it's on the smaller side which I sit fairly close too (9-10ft), so going higher is uncomfortable in my set up.
post #376 of 385
Originally Posted by Kelvin1965S View Post
About '10' biggrin.gif and an extra QC check before shipment AFAIK. There might be a difference in warranty too, but not completely sure.
tongue.gif 10 more just sounds good!
That is cool. Thanks for the info!
post #377 of 385
Originally Posted by sanderdvd View Post
There not much talk about the Mitsubishi HC8000D yet. Would love to hear more about it as it seems a real 3D killer!
Hi,
there are here a review from Projector Central :
http://www.avsforum.com/t/1432352/mitsubishi-hc8000
post #378 of 385
I've used electric screens since I got into home theater. They have some advantages over fixed screens ( except for cost ). A " free " electric screen salvaged off a construction site got me started - that " free " screen has cost me tens of thousands of dollars by now ( every one well spent !! ).
post #379 of 385
Originally Posted by Craig Peer View Post
I believe electric HP's are quite a bit cheaper than fixed.
post #380 of 385
post #381 of 385
Don't you have 2?
post #382 of 385
2 screens? Yes - a 2.35:1 and a 16:9 screen.
I think they both cost me more than a fix screen would have..........eek.gif
post #383 of 385
Anybody have an idea when the Mitsubishi HC7900DW will be coming out? IM very interested in that projector from the specs that has been posted on the net..
post #384 of 385
Might want to shell out the extra $500 for the 8000.
Projector Central review on the HC8000
post #385 of 385
Maybe you should give me one since I still can't make a decision on a screen smile.gif
