So I finally sat down and unboxed my Pioneer VSX-1121-k receiver last week (purchased on Black Friday 2011), and started setting it up in the family room. I was trying to use the preouts on the receiver to hook up my wireless Klipsch lightspeakers and also my Sennheiser RS170 wireless headset. For the life of me, I could not get any sound to come out on the lightspeakers or wireless headsets using the preouts on the back of the receiver. After some searching online, I just now discovered that the Pioneer (and apparently many other non-high-end receivers) does not convert digital input signals to analog signals necessary for use with the preouts.
I suppose I can try running analog audio connections for each of my digital devices and see if I can make that work, but I'm curious whether there are any reasonably priced receivers that have the ability to convert digital input signals to analog for use with the pre-out connections--hopefully one with Airplay support as well. Any suggestions?
