fake / false wall questions
post #1 of 7
Hi all,
After days of researching meditating, measuring, praying and buying, I've decided to build an acoustically transparent fake wall to put my speakers behind. I plan to use 2x2s to make a frame where I'll attach my (acoustically transparent) projection screen and acoustically transparent speaker fabric.
The problem is, I can't figure out how to make the wall "moveable". What I mean is that I want to be able to move the wall and get behind it to do stuff. I wont be doing it often (once everything is setup I wont have a reason to go back. May be if a speaker dies and has to be replaced), but I do need access.
How do you guys handle it? Are there instructions somewhere? I can potentially build a door. Another option was to drill 2x2s in the wall, put Velcro on them and then use Velcro to "stick" panels onto the frame. That way I can remove those panels and get behind to get stuff done.
I dont care if access is comfortable. It just has to be (barely) big enough for me to get behind and to potentially move speakers / receiver etc. in and out.
post #2 of 7
For a simple "wall" with friction-fit (removable) panels, check this thread out.
http://www.avsforum.com/t/837848/minimalist-approach-to-screen-wall/60#post_20383718
post #3 of 7
Some folks have mounted the screen on hinges so they can swing the screen up to get access to the space behind the false wall.
post #4 of 7
With the left, right and bottom panels on (didn't have the top in place in this picture). Left and right are friction fit between the stage carpet and soffit / bulkhead fabric; bottom is friction fit between the stage carpet and the bottom velvet of the screen frame (and the left and right panels).
post #5 of 7
Now why didn't I think of that! I am so doing it. Thanks.
post #6 of 7
I am using BIG's minimalist screen wall, and it was VERY easy to install, though I'll admit the hinges idea is kind of cool. When adjusting my subs I wish there was an easier way to get back there, but you rarely ever need to do so.
post #7 of 7
My screen is pressure fitted into a framed opening. To gain access to the stuff behind the screen I just remove it.
