I am a newbie in terms of A/V in general. I've done a bit of research but being a newbie it is hard to understand the precise information in forum posts - don't want to miss any important details here.
I have a new house and I am in the stage of wiring it up for Home Network, video and audio. I am looking at the cheapest way to be able to share video sources to multiple rooms. The detailed information is as follows.
- I have basement, floor 1, floor 2 & floor 3
- I plan to wire the entire house with Cat6 or Cat5e Ethernet (using multiple switches to reduce wiring cost)
- I plan to put majority of the video inputs (Apple TV, HDTV cable box, Blu-ray, Satellite TV) in basement which functions as a dedicated home theater
- a projector will be set up at the baseline home theater
- a 7.2 receiver at basement
what I want to achieve
MUST
- affordable
- share the multiple video sources to different rooms
Nice to have
- master bedroom (floor 2) would probably have its own 5.1 speakers. if this is the case, any way to leverage the receiver at basement?
- to be able to play MP3's via Apple TV (basement) in dining room, or some other room
Thank you very much for your advice. I apologize if the details are not clear to you.
MUST
- affordable
Nice to have
