AVS › AVS Forum › Audio › DIY Speakers and Subs › New Home Theater Speaker Build
New Home Theater Speaker Build - Page 4
post #91 of 94
Originally Posted by Brad Horstkotte View Post
That's what I did, about 2 parts water to 1 part Titebond, worked great.
Thanks Brad. I think I'll try that. By the way, did you ever get your theater completed? I'm about ready to build my false wall you inspired me to go with. Just got to get the walls painted and then I'll build it. Trying to figure out if I want to build the false wall before flooring or do it afterwards kinda as a "temporary" type wall that I can take out if needed later on. I plan to make the structure out of 2x4's and then use velvet covered panels to fill it all in.
post #92 of 94
I actually never put a "tada, finished" in my build thread, because it seems there were always more things to do - maybe I should at least put a "95% finished, the last 5% will have to wait until I'm done watching movies" stamp in it though, and add some final(ish) photos.
post #93 of 94
Cool. That would be good. By the way, I just realized under your avatar that you live in Torrance. I've been there several times for work. Usually stay there at the Doubletree. I like it out there. Just couldn't afford to live there.
post #94 of 94
Originally Posted by mathu126 View Post
Here they are. All 9 cabinets ready for primer/ paint.
Plan on applying primer this Saturday.
That is a fantastic picture!
