Originally Posted by
RandyWalters
Since Plasma TVs are phosphor-based, they are much more CRT-like than any LCD TV or LED LCD TV. Unfortunately there are no more good Plasmas in the under-50" size range this year (the good ones start at 50").
If we are going by "uses phosphors" to mean "CRT-like" then LCDs are CRT-like as well, seeing as they use phosphor-coated LEDs/CCFL tubes.
While Plasmas are emissive displays and don't have the viewing angle issues of LCDs as a result, that's about it as far as similarities go. The image they put out is very different from a CRT display.
phillyguy83
I have three Sony HD CRT televisions, and I love the picture that each one produces. However, I know the day is coming when they'll die.
Wait until they actually do. Flat panels are better in some regards, but nothing is as good overall as a well maintained and calibrated CRT in my opinion.
The only thing a Plasma does better than a CRT is resolution. Everything else is worse. (contrast, motion handling, viewing angle etc.)
phillyguy83
Specifically, I'm looking for a TV that can reproduce the type of motion and black levels that a HD CRT can produce. I hate motion blur and that flat, video-like look that a lot of LCDs produce, so I'm guessing that a plasma is probably my best bet.
Plasmas cannot match a CRT when it comes to black level. Local-dimming LED-backlit LCDs
can. The flat looking image on many LCDs is simply caused by their poor contrast ratio (inability to create good black levels) and the matte surface that was popular a while back. An LCD with a bonded glass front like Sony's HX909/929 has just as much depth to the image as any CRT. The video look is an image processing option that can be turned off. I'm not recommending that you go out and buy an LCD, but just because
some (OK, the majority) look bad doesn't mean that they
all do.
phillyguy83
I don't want a really large TV, either (42" is the max I'd want), because I watch a lot of SD content and would like to find a TV that produces a quality image for regular DVDs like the CRT does, and it seems that the larger the television goes, the worse the SD picture gets.
The size difference between 42ʺ and 46ʺ is not so great that it will have a significant effect on the quality of SD content, however if 1080p plasmas are no longer available at 42ʺ, buying a 46ʺ 1080p display will be significantly better.
Mik James
A lower res panel might look better for sd content but I think you would lose that benefit with the odd resolution of 1024x768.
With the exception of a CRT which can actually scan at the resolution of the source material, you
always want as high a resolution display as possible, regardless of the source resolution.
While it's not 1024x768 vs 1920x1080, here's an iPad 2 (1024x768) and iPad 3 (2048x1536) comparison that illustrates it very well.
As you can see, while the source resolution is identical, the image is significantly better on the iPad 3 display due to the increase in resolution.
