AVS › AVS Forum › Display Devices › Rear Projection Units › Is there a way????
Is there a way????
post #1 of 4
I have a mitsubishi 65315 hd RPTV form 2005 in excellent working order (so i am not buying anything new), but it only displays 480p and 1080i. I just got a apple tv 2 cheap and i know it has 720p output. Is there any knid of inexpensive switch/box that would upconvert the signal to 1080i (according to my owners manual my yamaha rx-v671 reciever will not do it) and when i hooked up my sons ps3 any game that was native at 720p downscaled to 480p. I'm trying to avoid this with the apple tv 2
post #2 of 4
Unfortunately, no 720P on these models ( I have a 65813), and no hardware device will change that. There is a Panasonic 65 inch CRT RPTV that can display 720P. cool.gif
post #3 of 4
my yamaha rx-v671 DID upscale to 1080i from 720p thru hdmi even though the manual said it wouldn't, apple tv 2 looks pretty good
post #4 of 4
Sorry about my initial response. I hurriedly read your original post and misunderstood it. I somehow read it that you were trying to output 720p to the Mits, which can't be done. confused.gif
Glad you solved your problem.
  Back to Forum: Rear Projection Units
