I never thought I would be this excited to be getting spandex in the mail... (will be here friday) I ordered 3 yards of the matte Moleskin in silver and white to do a double layer to catch any light that leaks through. Can't wait to test out the each to see which offers the best results. From what I've read not much is lost on the whites with the silver and it definitely helps out the blacks.
Its been a long 2 1/2 year journey to get started finally on the basement but its finally time. I have been lurking from time to time and am ready to get at least the frame and screen mounted this weekend. A little background and pictures
This is the basement trying to get ready for the screen. I have not done any treatment to it obviosuly and have a couple things to do to really get it ready for a full blown theater room. The room itself is 24' x 12'8" with a drop ceiling height of 7'. There is a door at the back but I have complete control of lighting in this room. Right now the projector (Epson Home CInema 8100) is ceiling mounted 14' back from the wall and about 4-6" from the drop ceiling
It is hung by a custom made bracket and down-rod that I made from another post on this site (sorry I cant remember which one). There are springs to dampen any movement and to be able to adjust for any off alignment there is.
The walls are a very very light baby blueish wood paneling that reflects a ton of light back onto the screen which I would like to either paint or cover with black cloth of some sort (any recommendations are GREATLY appreciated for room treatment) as well as paint the ceiling black back to the projector.
Right now I have calculated I want roughly a 120" to 133" screen (133" being very immersive and what I am liking with just being projected onto the wall). Using the Epson calculator it is saying I need 13'1" throw distance for 133" screen although the Projector Central Calculator is stating that a 120" screen needs 16' throw distance. I know with lens shift and zooming I have a lot of placement liberties but would like the best output from the projector at the best distance. I can mount to projector anywhere.
Right now I have a BOC I have been using for the last 2 years mounted to the drop ceiling frame just to show how the image looks at 133" or so screen size.
So my questions being what screen size do you recommend (all items in the front of the first picture are being relocated except the center channel and the two towers which are AV123 Rocket 450's) and what placement distance for the projector for optimal light output? I am just worried I am putting to much screen in the front of the room and it will look cramped with 130". I am not married to the spandex screen so if you think any other type of screen (Sintra, WA, etc) is better suited then no worries on that end either.
Aslo any guidance on treatment for the room to negate any light being thrown back at the screen (I have no idea what to do with my shiny brown checkered floor....)
Thanks guys, reading all the threads I have learned a lot towards making this happen.
Edited by memphisanid - 7/11/12 at 10:41am
Looks like you've got a sweet 70's basement going.
