AVS › AVS Forum › Display Devices › Flat Panel General & New FP Tech › Shelf Mounting a LCD TV Without (typical) Stand
post #1 of 3
I'm looking for a few options for mounting a 23" (or so) TV into a built-in shelf/cabinet that is open in the back. The shelf opening is 22.75 x 14 of which 21.75 x 13 is open in the front (small amount of trim around the sides and top). I have found a TV virtually the same size of the finished opening and would love to mount it flush at the front of the opening... which would make it appear it was dropped into the opening. I have all kinds of depth in the shelf to use a stand mount and the TV has the standard size bracket for mounting. I just need some type of mounting bracket that will do 90 degrees and is long enough to sit behind the TV (not under it) and hopefully is self-supporting not something I have to permanently attach to the inner shelf (although that's an option).
The TV won't really be used except for a couple of times a month (tops) so I don't want to invest say over 100 bucks or so in the mounting and since the mounting will be completely hidden (except when I open the doors (equipment cabinet) from the rear it doesn't have to be pretty...
post #2 of 3
Perhaps something like this would work, but it would need to be attached to the shelf or something.
http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10828&cs_id=1082802&p_id=7844&seq=1&format=2
post #3 of 3
Something like the Monoprice #8255 (or #5921 corner-friendly mount etc) should work if you bolt it to the side of the opening, they would have plenty of extension range to swing the TV 90 degrees and place it flush with the front of the cabinet:
http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10828&cs_id=1082806&p_id=8255&seq=1&format=1#largeimage
http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10828&cs_id=1082806&p_id=5921&seq=1&format=1#largeimage
Other Monoprice Mounts:
http://www.monoprice.com/products/subdepartment.asp?c_id=108&cp_id=10828&cs_id=1082806
