AVS › AVS Forum › Other Areas of Interest › Camcorders › Sony HDR-GW77: waterproof, dustproof, shockproof small HD camcorder
Sony HDR-GW77: waterproof, dustproof, shockproof small HD camcorder - Page 22
post #631 of 637
Just got the gw55 ( the uk version of the gw77 ) and what a fantastic camera !
Just wondered if anyone got any experience of using alternative batteries ?
It seems the standard one is the bg1 960mAh non info lithium.
Apparently the fp1 is the info lithium version, does this camera support an actual battery time readout ? Or will it still be the 4 battery bars ?
Also there seem to be a number of non-sony versions of higher capacity versions eg 1100mAh by ex-pro (white series), this may be a worthwhile 10% increase in battery life if true.
Anyone got any experience of these on this camera ?
post #632 of 637
^ The fp1 will not show minutes on battery life. I dont know about the gw55 owners manual but the gw77 manual states that when using the fp1 time remaining will not be displayed.
post #633 of 637
Yes, your right - looking in more detail at the manual the GW55 states the same.   Shame ....
Very roughly it looks like each battery bar ( of 4 ) last about 10 - 12 minutes.
Came across the Hahnel range of batteries, found one for this camera
http://www.hahnel.ie/index.cfm?page=digitalcamerabatteries&vId=1&pId=635
- so a 1050mAh rating could be a good addition for this camera, for just squeezing a touch more use per battery change.
Also the ex-pro 1100mAh one here:
http://www.amazon.co.uk/Ex-Pro%C2%AE-Replacement-Battery-1100mAh-Description/dp/B00EXNVRAW
post #634 of 637
I lent my GW77 to my BIL and in our hurry to try and download some shots of the grandkids skiing, I thought I deleted the videos. But when I power on the camera I can see and watch the videos, so I'm thinking the clips are in internal memory? Can I download the video clips somehow? I connected the USB to my iMac and by mistake used image capture and remove images once downloaded. So it downloaded all the stills and I have those... but none of the movies downloaded.
Anyone want to offer what might be the best way to import those movie clips? My BIL uses a PC and his programs are PC-specific including Stitch. What is the best/simplest way to download clips and do basic edits/transitions?
TIA!
post #635 of 637
on my hdr gw 77v, the zoom button is noisy and squeaky when pressed, you can hear it clearly when filming (zooming in and out), the whole Thailand trip videos are effected because of this sound (i could hear it when pressing but i thought it will not appear in the video itself but it did!), now i am avoiding this by using the W / T on the LCD screen but this is not convenient since you cant control the speed of zooming and its hard to control...
Anyone has the same problem i am facing?, will dropping oil on the sides/ edges of the button be a good idea (since its water-proof will it reach the interior of the camera and damage it?)
i hope i can fix this problem because the camera it self is amazing
post #636 of 637
Originally Posted by markr041 View Post
The slow smooth record looks pretty good. I haven't tried it yet.
The shallow dof comes from a combination of the very fast lens of the GW77 (f1/.8) at wide angle and close distance to subjects. Also, using the tele end and focusing on specific subjects will also give shallow dof, depending on distance.
Hey mark I've be been a follower to your posts for some time now, I ve been trying to achieve similar DOF with my g77 but didn't get good results yet smile.gif, I knew about the telemicro mode and I've been able to pull some good shots with this but a wide angle and close distance to object I can't tell what did you mean exactly a simple explanation of what to do with the menu and what to select is highly appreciated since and as you can tell from my simple language I am no expert thanks
post #637 of 637
DOF will be shallower the larger the aperture (so largest at f1.8) , the longer the focal length, and the closer you are to the subject. The GW77 has its widest aperture only at the wide end, so if you open the aperture to f1.8 you have to shoot close to get shallow dof (and it will give you that). Tele-macro mode extends the lens to the longest focal length and enables you to be close to the subject, so it minimizes dof. Those are the two tricks.
Edited by markr041 - 4/6/14 at 7:00pm
  Back to Forum: Camcorders
