AVS › AVS Forum › A/V Control & Automation › Tweaks and Do-It-Yourself › Installing pre-outs
Installing pre-outs
post #1 of 22
has anyone ever put in their own pre-outs to an AVR that did not have pre-outs?
post #2 of 22
Yes
post #3 of 22
Originally Posted by SAM64 View Post
Yes
good to know its do-able. did you follow a guide or anything? Do you know of any websites or anything to help.
post #4 of 22
I just traced the circuit and tapped the signal prior to the power amps.
post #5 of 22
did you just solder a wire onto it and then solder it to a rca plug like this? http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10430&cs_id=1043002&p_id=4121&seq=1&format=2
did you ground the sleeve or did you connect it to the negative circuit on the amp?
use any resistors or anything?
Edited by WagBoss - 7/12/12 at 7:04pm
post #6 of 22
Originally Posted by WagBoss View Post
...sodder...
I think you mean "solder". "Sodder" is something else entirely.
post #7 of 22
ya ya .. lol
post #8 of 22
I tacked a wire onto the a solder pad, this feeds the signal to another board with the buffers and connectors.
The sleeve on an RCA connector is connected to ground, nothing else. Do not connect it to the negative power supply.
Resistors are after the buffer.
BTW, you linked to an RCA to BNC adaptor.
post #9 of 22
i know, that is what i have lol. it should be fine right, still have a center pin for positive, and a sleeve for ground? would you mind giving a bit more in depth description of tacking a wire onto the solder pad, and what buffers you used? by a solder pad do you just mean like a separate board with the rca connectors on it? What did you use as a buffer?
post #10 of 22
It's an adaptor, you need a female RCA connector(s)
In my case, the power amps are on hybrid modules. I found the input pin and tacked a wire onto this where it is soldered to the board.
NE5532's. I had them on hand and they're relatively cheap.
post #11 of 22
can you send me a link to what connector? something like this http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10426&cs_id=1042601&p_id=6555&seq=1&format=2 ? How is using a female RCA any different then a BNC, both have an inside + pin and a grounded sleeve?
would this type of board work http://www.aliexpress.com/product-fm/497088216-DIY-AMF-NE5532-Stereo-Preamp-amplifier-board-wholesalers.html
Edited by WagBoss - 7/13/12 at 7:15am
post #12 of 22
Here's an example of a chassis mount RCA female.
http://nerveaudio.com/connectors/chassis-mount-female-rca/
You probably don't even need the buffers. How many channels are you breaking out?
post #13 of 22
I'd like to do LCR
oh nice those are way better connectors! lol, but is there a problem with mine, obviously they're not optimal, but how are they any different, i just won't use BNC locking mechanism, I can still just sodder to the ground sleeve and the inside pin?
found some cheaper ones.. http://www.ebay.com/itm/3-Pair-GOLD-Amplifier-Audio-Terminal-RCA-CONNECTOR-FEMALE-CHASSIS-Panel-PCB-Jack-/300689680791?pt=US_Amplifier_Parts_Components&hash=item4602806997#ht_2880wt_1216 with free shipping to canada too smile.gif lol
Edited by WagBoss - 7/13/12 at 12:30pm
post #14 of 22
Yours are adaptors, they adapt a male RCA to a male BNC. They're not chassis mount connectors, how would you mount them?
Also, they're not gold plated...you don't want any gold plated connectors because they'd be very expensive and the gold will rub off the first time you mate them.
The metallic yellow colour, that they call 'gold', is cadmium chromate...it offers much better protection than gold.
You can buy these locally as well.
post #15 of 22
hot glue? :P lol. i just boughthttp://www.ebay.com/itm/3-Pair-GOLD-Amplifier-Audio-Terminal-RCA-CONNECTOR-FEMALE-CHASSIS-Panel-PCB-Jack-/300689680791?pt=US_Amplifier_Parts_Components&hash=item4602806997#ht_2880wt_1216 off ebay, 6 for $2.50.
post #16 of 22
so your saying i won't need a buffer? Why did you use a buffer? what does it do?
also, when tapping the line before the amplifier, will it still have the "EQ settings" from the roomeq programs? or does it implement that feature during amplification?
post #17 of 22
I used a buffer to provide balanced outputs.
All eq, correction etc is done in a dsp, before the power amp.
post #18 of 22
oh ok. so basically all I really need to do is find a line I can tap right before the amplifier and connect a wire to the RCA + pin and then ground the RCA sleeve. simple as that?
post #19 of 22
You can buy a box to convert speaker level to line level. A brief search shows that manufacturers include Audioplex and Xantech.
post #20 of 22
post #21 of 22
Yes
post #22 of 22
If you are still looking for responses to your question, I have done this several times. One thing I would suggest however is to put a DC blocking electrolytic cap in series with the connection to the outside word. A 1 mfd, 25 volt cap will work fine and polarity is not important as long as BOTH channel caps are installed the same way.
  Back to Forum: Tweaks and Do-It-Yourself
