Originally Posted by MississippiMan
(Color Components)
100ml - filtered/distilled water for rinsing color components from utensils
50ml - Liquitex Basics - Napthol Crimson Red
25ml - Liquitex Basics - Phthalocyanine Green
16ml - Liquitex Basics - UltraMarine Blue
9ml - Liquitex Basics - Cadmium Yellow - Deep Hue
Liquitex Basics Gold 1.50 oz (...get a small tube of this and have it handy in case you notice any tendency of the completed Mix/Colorant to push toward Blue)
Be careful using those Glass Mirrors!
(Color Components)
OK, so that's the whole recipe? Using the fine tip on the sprayer, approximately how much mix do I need to cover the ~30 sq feet of the mirror? (or are those quantities listed above sufficient) I want to make sure I order enough to cover it the first time
Also hah, I heard a Lowes' commercial for the HV2900 - $99
Yay eBay!
They are mostly intact, a few scrapes on the edges, but fortunately they were not glued onto the walls - just a top & bottom metal rail. Measured in at 1/4" thick. I think I am going to go with the largest mirror in the bunch in order to fit the 800p resolution of the projector; I've decided to use a PC as the primary source, so I can use the full resolution for other stuff (gaming, web surfing, etc.). Using the 16:10 calculator below, it looks like I can do an 84" W x 53" H screen, with a 99" diagonal. The largest mirror I have is 5' x 7', so I'd have to trim off 7" from the height, which I'll do with some black velvet.
