This thread is for Sammy2 who asked in my network connection issue thread (which I resolved and determined my router was not gigabit)
Here is the thread:
http://www.avsforum.com/t/1419935/help-i-only-get-11mb-sec-transfer-speeds-to-and-from-my-whs2011-media-server-what-should-i-do
Here is the question: (I only started a new thread since the topic is not a connection issue on a server)
I believe that 1024MB = 1GB and so 100 GB would be 102,400 MB. Someone confirm this for me or else everything else I do is wrong. lol.
But if so- It takes me about 20-21 minutes over my server and network to paste 100GB from my Desktop to my server. This is at about 80MB/sec.
A green drive is faster than that alone- probably closer to 100MB sec in good setting and 90MB sec in a conservative estimate - especially when it's older or filled up.
So it would take 18 or so minutes on a green drive transfer speed.
In contrast, a good 7200rpm set up (I used my Samsungs) can approach 150MB sec. I also got 134MB/sec on another 2TB Hitachi 7200RPM. Pasting from my SSD.
First of all the speeds your posting for a green drive are a pipe dream.
Green drives are slow.
I will repeat: SLOW.
I was accurate by my experience when I used 90MB/sec transfer. I own 5 different versions of GREEN drives. Different sizes and brands. All modern. All hooked up directly to motherboard with SATA cables. Some even SATA3, both drive and motherboard port.
You might get higher than 100MB/sec on certain easy things but realistically your not going to see speeds much faster than that.
In contrast I get 150/MB sec on my 7200rpm HDD.
I just tested:
So it would only take 102,400 divided by 150 = 682 divided by 60 = 11 minutes. 11 minutes for a really good 7200rpm HDD. Closer to 13 for normal. Closer to 18 for Green. and 21 minutes over a basic network at 80MB/sec transfer.
I have seen many with network speeds about as fast as a green drive. So to answer your question- it takes about as fast as your 5900rpm drive can handle- or write at.
A good network is about as fast as a 5900RPM write speed I believe. Both near 100/MB sec.
Edited by Mfusick - 1/23/13 at 6:30pm
Here is the thread:
I just tested:
