AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Bi-amp AVR-1913 with 4 ohm front speakers
post #1 of 4
Methinks this might be a foolish question but, then again, I've never been accused of being that wise:
I'm using the above receiver in a 5.1 setting. My front speakers are 4 ohm PSB Stratus Gold i's. They are bi-ampable. Works great so far except that when playing music (stereo) at higher levels (-5.0 db) for a moderate length of time, the amp will shutdown due to heat.
Lots of space surrounds the receiver. I'm not playing nearly as loud as my previous receiver (Pioneer VSX-1016) which was also not rated for 4 ohm loads.
My question is this: if I bi-amp zone 2 to my speakers, do you think the use of the currently unused amp section will allow me to drive my 4 ohm speakers to high levels with less heat related shutdown?
G.
post #2 of 4
No.
Unfortunately you have the wrong choice of receiver with your 4Ω speakers. If you need to play at those levels you need to upgrade to a more powerful receiver rated for 4Ω, or a receiver with pre-outs to use with ext. power amps.
post #3 of 4
When there's Klipsch, why would anybody who wants loud, want 4 ohm speakers which robs amplifier and speaker efficiency?
(And FWIW, yes, I've bi-amped my Klipsch with tubes and SS to mellow the horns when playing violins.)
With all due respect, I'd buy a new set of speakers before dealing with 4 ohm speakers. The point, why are you not considering purchasing a new set of speakers as opposed to re-amping the speaker system? confused.gif
post #4 of 4
As Kilian.ca notes, you need a more powerful amp to power those puppies. An AVR that would be more line with those high quality speakers would be the Denon 4311CI which not only can power 4-ohm speakers, but also uses the far more advanced version of Audyssey MultEQ XT32 which will make them sing even better. Give either Electronics Expo or AV Science sales a "call" for their best price. smile.gif
