Originally Posted by shadow39
Once I have the 50 I will do a full comparison of the two, I also will have the darbee in the mix along with the lumagen mini. I will only be able to test them at their short throw though as I can't go any further than 11'7". They will be tested on a Stewart 110" 1.7 reflections screen so will be interesting to see how much brighter the 50 is vs the 30.
Please understand that you are significantly below the recommended minimum throw for that material of 1.5 times the screen width would be the minimum in popular opinion and 1.7 or 1.8 would be better. At that throw, the screen will hotspot. If you put up a white field you will see the brightness will not appear uniform with areas, especially the center, when viewed from center will look bright. You might get some sparkeling also. Its livable I would think but don't blame the lack of uniformity in brightness on either the HW30ES or the HW50ES. Its the screen material being used at too short a throw.
Huh. But trying to defuse things raher an argue I said sorry, roll over and I will make it up to you. A little off color and meant as a joke here. But true,nevertheless.
