I would like to say I have narrowed it down to these brands for speakers and I want to use them for a home theater set up (5.1 channel only).
For the front left and right, I can either go with frontstanding or bookshelfs on stands. However, I don't know if either the Focal 806/807 or the Paradigm Studio 10/20 require special stands since I learned they are quite large.
Paradigm
Don't know if it's true that the S10v5 sound better than the S20v5 or not, but if I were to use one for the fronts, will I be missing much for music, like soundstages, imaging, etc.
The Studio 60's are kind of appealing (not price wise), but because I assume they will be amazing for music and live concerts on Blu-ray since they have a wider range.
If I go with the Studio 60's, will it be possible to combine older versions of the Studio 10's & 20's as rears, or will the sound and timbre, tonal quality, be noticeable different for HT movie use?
Lastly for music and fronts, will the Studio 60's be a night and day difference from the Studio 20's or 10's, when listening to music from CDs and lossless files?
Focal
If I bought the 807V, will this be about the same as the Studio 20 from Paradigm in terms of imaging, soundstage, clarity, mids, highs, etc? Which has a better bass? I want to forego the subwoofer completely, and will not be getting one for sure.
For the 816V, is it better, equal or worse than the Studio 60's? Let's forget about price between the two for a second --on pure performance and sound quality alone, which would be better?
Will it be a night and day difference if I use these as fronts, opposed to the 807V--meaning music will sound much more amazing on it?
I know this was a long read, but thank you for your time guys and your help!
Paradigm
Focal
In any case, the good thing is I know I'll be getting something soon here!
