Dual subs on mid walls (pic included)
Wanted some opinions on this, I lost all the notes I had on this subject so need a bit of advice. I have my dual subs place one on the front wall at around 60% ( cant do 50% due to TV) and one at 50% on the rear wall. The bass sounds good but with sub being so large I am getting a reflections from my CC and RF so I want a dual sub side wall/midwall placement. In the pic below you will notice I can not place the sub at the 50% mark do to the stairs but can place it at the 60% mark where the computer desk used to be (Not there anymore). On the left wall I can place it anywhere.
I have been told to place one sub at the 25% mark and one at the 50% mark, do you guys agree with this? I was thinking of putting the subs either both at 55-60% directly across from eachother or I could put one sub at 50% and one at 60%.
My seating is at 40% and right behind the seats in the pic before the hard floor is the 50% mark. So if I do the 50%-60% placement both subs will be behind MLP.
I rather keep the subs out of the front soundstage if possible, but not if it is going to hurt bass. Room is fully treated with GIK acoustics tri-traps, 242 panels and 8" bass traps on the rear wall.
pic:
pic:
