AVS › AVS Forum › A/V Control & Automation › Tweaks and Do-It-Yourself › Intergrate Subwoofer Cabinets into Plasma TV Table.
post #1 of 6
I've had a hard time trying to find a cabinet/subwoofer solution. I developed the following idea, thinking it would save some space, reduce clutter, and clean up the game room at our home.
My question is, has anyone had any experience with building subwoofer cabinets into an entertainment center? Any drawbacks, concerns with vibration causing damage to the equipment, etc?
I'm debating on having a friend build the design for me, since he has access to tooling etc. He's saying it doesn't look too complex, including inner baffles for the subwoofer cabinets etc.
Thoughts?
post #2 of 6
May not be the ideal location, within the room, for acoustics.
You could cut out the bottom of the cabinet so the sub sits on the floor. Use acoustically transparent fabric to cover the front. Change the design so the cabinet has lower feet, so you can't see the bottom of the sw.
post #3 of 6
Realistically the height shouldn't be any higher than our present console we have now. The width of the unit is where we're making up the space. The feet are just an idea, my wife was saying that it would look a little better in the room if it was off the floor a little. Acoustic cloth will be used to cover the faces of the subwoofers, I just have to get with my cabinet maker about finalizing the design.
What I'm looking to achieve is something similar to this, just without all the stuff around it.
Edited by Big-Sexy907 - 7/16/12 at 2:40am
post #4 of 6
At the risk of having to turn in my Man Card - a small space under a static piece of furniture is a PITA for dust and pretty hard/impossibe to vacuum.
I think NeuroRad's suggestion is a good one - you'll have a visually integrated piece, but the subs will be physically decoupled from your electronics.
post #5 of 6
I'd have concerns about rattling noise, with the built in subs. I guess it wouldn't be great for the electronics either.
If you want to spend big bucks, you can hire a speaker company for built in subs, to your design. They may help with cabinet design. Bay Audio and California Audio Technologies, I've read, are the go-to guys for high end custom speakers.
post #6 of 6
+2.
  Back to Forum: Tweaks and Do-It-Yourself
