Originally Posted by
GPM
Didn't know there was a Superbit version. Frankly, the one SB movie I have [Lawrence of Arabia] is so marginally better than the DVD on a calibrated 65" RPTV that I didn't waste any more $$$ on them.
I have the Lawrence Superbit as well, and used to own a few others (Underworld, Starship Troopers...). I think alot of folks got the SBs for the DTS tracks, rather than the higher bitrates. There is a difference in the image quality though, and it's most noticeable in action scenes where there's alot of movement and you're more likely to see compression artifacts/macroblocking on the lower-bitrate recordings. I could definitely see a difference in some of the action scenes in Underworld, even on my comparitively smaller HD screens.
Most of the SBs are probably obsolete though since the arrival of Blu-ray.
GPM
Regardless, I'm satisfied enough with the DVD as it looks as good as I remember it at the movies:
Fair enough. The 2008 CE DVD of Heavy Metal could well be from the same xfer as the BD edition. The BD looks pretty damn good to me though, and I would strongly recommend it to fans of the film, especially at the current $5 price (with tradein). The BD xfer is on the grainy side (which could be somewhat distracting for some folks), and detail could maybe be a tad sharper/better-defined, but they nailed the color and contrast on this edition IMO. And the upsides on the disc far outway the minor issues in it's PQ.
GPM
Sure wish my store had more to choose from though, especially $9.99-14.99 ones.
Agreed. The selection is pretty abysmal at BB. They only stock new releases, and older titles which are still good movers/money-makers for them. Fortunately, I also have access to a really good second-hand store which has a much better selection to choose from, and they're usually happy to take any gently-used BDs (or DVDS) I don't want for credit at their store.
I think discs are on the way out though. Streaming seems to be the wave of the future.
GPM
BTW, how do you find out about these sales? I can't even find it on their website.
GM
I found out right here.
Edited by ADU - 8/7/12 at 3:35pm
