AVS › AVS Forum › Audio › Receivers, Amps, and Processors › How to listen to the Audyssey flat curve on Onkyo TX-SR608?
post #1 of 4
I know there is no way to manually switch it, however, does this AVR switch to Audyssey's flat curve automatically when only in THX mode?
If not, what sound mode do you need to be in to get the flat curve?
Gear mentioned in this thread:
post #2 of 4
which receiver do you have?
post #3 of 4
Sorry, fixed the thread, thought I was posting in the 608 official thread as a reply!
post #4 of 4
For your receiver the only way to listen to the flat curve is to use a THX mode. All Onkyo receivers before xx09 series that feature Audyssey did not allow you to choose the flat curve manually.
